My Civics HID DIY Installation - Page 8 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 04-08-2007, 01:12 AM   #141 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
just awesome
2rotormotor how did you install in 15 minutes? i havnt done it yet but i sure would ilke to know to save time
datbacker59 is offline   Reply With Quote
Old 04-08-2007, 01:35 AM   #142 (permalink)
Luke Watkins
car on jacks, remove wheels and wheel liners very quickly, cause thats the longest part.
plan where to run the wiring looms before hand, and get them in and zip tied quickly.
and liner retainers are a *****, make sure you get a good flathead deep in them or they will tear and shred, i killed 2.
TurboGC8 is offline   Reply With Quote
Old 04-08-2007, 04:12 AM   #143 (permalink)
Quail Man!
GETxERxDONE's Avatar
Nick
Originally Posted by TurboGC8
and here is a video of my the headlights i took.
http://www.youtube.com/watch?v=7qp-A1Hpyp4
mmm nice..what song was playing? sounded good
GETxERxDONE is online now   Reply With Quote
Old 04-08-2007, 09:06 AM   #144 (permalink)
Luke Watkins
im not sure of the song but the group and album was
bloodlined calligraphy - they want you silent
also check out
all that remains
underoath
atreyu
hand to hand
the burning season
myspace.com/bravethefire
myspace.com/adyingregime
myspace.com/fireatwillfl
myspace.com/beneaththesewords
myspace.com/weareactionrock
myspace.com/shadowagency
myspace.com/ten13concept
sorry for
Old 04-10-2007, 01:37 AM   #145 (permalink)
sweeeet. I hope i'll do it right
joenguyen is offline   Reply With Quote
Old 04-10-2007, 12:11 PM   #146 (permalink)
dario's Avatar
that write up was AWESOME!!! i actually feel comfortable enough to do this myself! thanks! +1
dario is offline   Reply With Quote
Old 04-26-2007, 02:18 AM   #147 (permalink)
Lenny
I threw my HID's on my ishh, today. Process went smooth the most annoying thing is getting the light in on the right side, taking off the fasteners and getting the HID socket to go into the Lamp socket. Took me about 3 hours cuz i'm slow like that. Thanks for the DIY
Facedagod is offline   Reply With Quote
Old 04-27-2007, 12:07 AM   #148 (permalink)
HondaFREAK's Avatar
simple wiring diagram for using the relay and fuse kit.
if you want to use this in the original post feel free so people dont have to search all the way to the 14th page to see this diagram.
Just to be safe, I'd put 10amp fuses in between the relay and the ballast connectors...just to be safe.
HondaFREAK is offline   Reply With Quote
Old 04-27-2007, 11:56 AM   #149 (permalink)
Orient Express's Avatar
There he goes confusing the nubies !
With the redundant and unnecessary relay harness again.
So for the umteenth time again:
There is no need for a relay harness on an 8th Generation Honda Civic. It is completely redundant to the built-in wiring down to the gauge of the wire. Save yourself the hassle, and just PnP!
The current generation Chinese Pnp kits available today draw less than 8 amps inrush at start-up and have a steady state draw of 3 amps or less. All of the chatter of 30 amps or more of current inrush are for the ancient HID ballasts that are out there, not the modern ones.
The paranoia of frying the electrical harness on your car from an HID kit is a total urban legend and has no basis in fact!
Orient Express is offline   Reply With Quote
Old 04-27-2007, 12:08 PM   #150 (permalink)
so i can just buy a HID kit... pop out the old one and put in the new one? does this mean i dont have to do stuff with the ignitor and ballast or whatever? im a n00b i know
Old 04-27-2007, 02:22 PM   #151 (permalink)
striker_1818's Avatar
Christian
follow that advice and PM me or call me in 3 yrs
striker_1818 is offline   Reply With Quote
Old 04-27-2007, 02:36 PM   #152 (permalink)
Yes, that is sorta correct. All you have to do is to unplug and remove your current halogen bulbs, plug that wire into the new HID ballast, and lastly install the new HID bulb in the headlight reflector, and connect it to the ballast.
The biggest issue is securely mounting the ballast in your car, and getting the new HID bulb to seat properly. The tolerances of the new bulb are very tight. Scroll down to the first entry of this thread to re-read my install story.
Also keep Striker's email address handy so in 3 years you can write him to tell him how much you still like your HID bulbs!
Old 04-27-2007, 02:42 PM   #153 (permalink)
Christian
yup yup
Old 04-29-2007, 02:32 PM   #154 (permalink)
FBPcsi2k7's Avatar
Alright, well, I had my friend (BMW mechanic, real pro) install my two 4300K HID PnP kits: 9006 for low beams and H11 for fog lights.
Thoughts on install:
1.) Easier to get at the bulbs and find mounting points by removing front bumper.
2.) Easier to get at the bulbs by removing headlight assembly.
3.) Frickin' PnP not so PnP as the stock plug does not make adequate contact w/ ballast leads. Remedy: ripped out the ballast leads from the casing and inserted metal clips directly into stock plugs, applied gasket sealer to water-seal & electrical tape to make it look pretty.
4.) Install of foglight kit a lot easier than low beam kit.
5.) Total install time: 3 hours!!! We're not exactly novices, so eegads.
Thoughts on product:
1.) Looks great!!
2.) Only had an issue on first powering on: one foglight wouldn't turn on... no probs since.
3.) Light pattern throws out a lot of light everywhere.
4.) Left headlight seems brighter than right headlight (aiming issue perhaps).
5.) Color-match fogs and low beams FTW!
Summary:
1.) I'd do it again for such a cheap DIY.
2.) Happy with the overall execution.
3.) Ripping apart the front end is like a fun puzzle; I'd recommend it for everyone. Kinda like taking the scenic route; you get to experience things about your car by taking the extra steps. By disassembling the front bumper and headlights, it made the caution and care a little less troublesome. If I went w/ the wheel well method, I woulda gotten all sorts of irritated and annoyed w/ how cumbersome trying to get at the components woulda been.
4.) I'll take all vital pictures in a week or so.
FBPcsi2k7 is offline   Reply With Quote
Old 04-29-2007, 07:48 PM   #155 (permalink)
Scrodums
You removed the entire headlight assembly to get to the bulbs? I think that's a bit extreme. It wasn't a problem for me to go through the wheel well at all. You just got to make sure you don't touch the bulbs. You can also find a place right there to mount the ballasts.
Old 04-29-2007, 09:28 PM   #156 (permalink)
+2 that, taking the headlights out to replace the bulb is overkill. Nothing wrong with going that way, but too much effort when the bulbs are easily accessible from the wheel well. With that said, if fog lights are part of the job, then pulling the bumper off is the best way to go, but not just for an HID low-beam upgrade.
As I have said several times, the only issue with installing the HID bulbs is that they are a tight fit. However lubricating the bulb mount and using a jewelers flat bladed screwdriver to push the bulb mount locked is the key.
I am interested in what brand of light you got that required you to modify connectors to work correctly. I would steer away recommending any kit like that.
Old 04-29-2007, 09:56 PM   #157 (permalink)
HondaFREAK's Avatar
the only thing the relay harness did for me was get rid of that annoying flicker I had a problem with
Old 04-29-2007, 10:21 PM   #158 (permalink)
asndragonboii's Avatar
What is that gasket sealer that you said you used to water proof it?
Old 04-29-2007, 10:24 PM   #159 (permalink)
HondaFREAK's Avatar
Goop seems to work well...any silicon sealant would work...Goop works the best though, from a friend's experience.
Old 04-30-2007, 12:25 AM   #160 (permalink)
Marc
I hid my ballast and wiring behind the wheel well cover, there was a perfect spot to place it. Probably a stupid question, but i will ask anyway. I am planning to install the OEM fog lights, actually i am planning to have it done by the dealer. I know they will remove the front bumper to install the fogs, what is the likely hood that they will notice my HID's and the balast hidden behind the wheel well? I don't want to have them confront me about the aftermarket lights and risk my warranty getting void. I guess I should have waited to have the fog's installed first, or I can remove the HID's and reinstall after. thanks
LACIVICSIGUY is offline   Reply With Quote
Instalação de xenon no farol baixo This thread Refback 09-14-2011 05:01 AM
HID: How much on an 8th gen??? This thread Refback 09-10-2011 03:07 AM
07' SI, HID install Q's... - HondaCivicForum.com This thread Refback 09-02-2011 06:02 PM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 100 11-11-2010 01:49 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
