#124 (permalink) | |
#126 (permalink) | |
#129 (permalink) | |
Luke Watkins
also one more question. are you supposed to plug just the one stock harness into the relay adaptor, and then leave the passenger side one out of the system all together? |
#132 (permalink) | |
#134 (permalink) | |
Just add 2 things in addition to my original post. 1. Make sure the Ballast is installed with the recessed electrical connector pointed down. This is to prevent accumulation of moisture in the connector. 2. Spray some spray lithium grease in the connector to further weatherproof it. |
#136 (permalink) | |
#137 (permalink) | |
Luke Watkins
My Civics HID DIY Installation |
#138 (permalink) |
Save yourself the pain
Leave the relay harness in the box, you don't need it, especially "just because"!.
And no the kit does not include instructions. It is a generic relay harness kit, and as rule of thumb for its installation is that if it is not obvious how to install the harness, you should leave it well enough alone. All you will do is introduce something into the equation that gives you more chance of having problems later on. You will gain no advantage to duplicating the OEM harness and its safety systems. |
#139 (permalink) |
Luke Watkins
installed last night, lookin good. I went with the 8000K.
and i did use the provided extra fuse and relay wiring. ![]() ![]() ![]() ![]() ![]() and a photoshop i did of a concept im thinkin about. ![]() HFP lip in black and suspension, and some Dragwheels, 16" or 17" gold spokes with polished lip. |
#140 (permalink) |
Luke Watkins
simple wiring diagram for using the relay and fuse kit.
if you want to use this in the original post feel free so people dont have to search all the way to the 14th page to see this diagram. ![]() and here is a video of my the headlights i took. http://www.youtube.com/watch?v=7qp-A1Hpyp4 |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
