#1264 (permalink) |
well .. i can't make my hid's work ... everythig was fine when i tried .. after complete the installtion ... nothing is working ... NO LIGHT ...
please help ... do we have to ground the ballast (mine one stick with battery cover & other car body with double tape |
#1266 (permalink) | |
Rick
that will answer your question and the answer is still YESSSS!!!!! |
#1267 (permalink) | |
Sam
![]() Can someone tell me where you got this kit from also. I skimmed through the thread, but found nothing. |
#1273 (permalink) |
![]() Join Date: Feb 2007
i was wondering the same thing. i get a flicker a couple minutes after startup. i think it might do it once per side, or just both of them twice. didn't someone say they fixed this issue....some ballast problem?
#1275 (permalink) |
Leonard
in the OP, the TS suggests you can power these with your OEM wiring.... why is this? I thought ballasts needed more power (to be wired directly to the battery) and that is why people buy wiring harnesses from places like Custom Lightz...
#1276 (permalink) |
Rick
negative
they dont NEEd more power BUT there is the possibility that they draw more current (spike) if they are bad the reason for the harness is in case of this spike, your stock wiring is safe now generally a fuse should be enough to take care of that BUT fuses have some play in them lol |
#1277 (permalink) | |
Erin
And, for the record, no I'm not imagining things. I'm particular about my grammar. I would have NEVER had a space between the ' and the following words like is above. Mods, WTF!? EDIT: LMFAO Apparently typing K_Light without the space will automatically remove it from your quote, just as above. That's the weakest thing I've EVER seen on a forum. Last edited by bikinpunk; 09-17-2008 at 02:24 PM. |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
