LinkBack (4) Thread Tools Display Modes
Old 06-16-2008, 09:19 PM   #1201 (permalink)
Rick
the sad part is they should have been destroyed, while they made some good computers, they were like having a gamecube or xbox.... after a year it was outdated lol (except game systems last longer lol)
and it saved their destruction not because of a superior product but because they could easily brainwash people into thinking they HAVE to HAVE IT to be COOL!
and it worked, kinda like starbucks lol
Honda on the other hand has been creating products that are GREAT for the environment, as well as peoples pockets... cant say apple has done anything... but say the recycle now (of course if u remember the whole battery fiasco u know the truth behind that one lol)
there is no ignorance here dude, and i do know it saved them, but personally they are a company that isnt really helping neone here in america
BUT all in all we can create another board for discussion on this if youd like
for now lets stick (as said many times before) to the topic... orients cool toys lol
Vfmp... read the whole thread and then decide.. thats what i did ;-)
tda1337 is offline   Reply With Quote
Old 06-20-2008, 05:56 PM   #1202 (permalink)
goofygamer's Avatar
I heard that if we install the HIDs then our high beams are going to be disabled because the HIDs take more power to use. Is that true?
goofygamer is offline   Reply With Quote
Old 06-20-2008, 06:03 PM   #1203 (permalink)
:beer:
Mikey6p's Avatar
Mukey
False.
Mikey6p is offline   Reply With Quote
Old 06-20-2008, 08:25 PM   #1204 (permalink)
Englishe30's Avatar
Mark
Its been a little over a year and not a problem with the hid kit
Englishe30 is offline   Reply With Quote
Old 06-23-2008, 06:04 PM   #1205 (permalink)
Coastale's Avatar
Wow, that is beyond false. So false, actually, it's opposite. The HID draw is only 35W, not the 50W like the standard 9006 bulbs that came with the car. The 9005 High Beams are completely separate. Ask your friend who told you thing about the high beams being disabled for his advice on an important subject, and then do the exact opposite of what he says and you'll be all set.
Coastale is offline   Reply With Quote
Old 06-29-2008, 09:09 PM   #1206 (permalink)
Excalibur's Avatar
Jeremy
Nice writeup. I'm gonna have to look into this. I want to mount the ballast up top so I don't have to take off the bumper every time.
Old 06-29-2008, 10:29 PM   #1207 (permalink)
Orient Express's Avatar
Can you explain what you mean by this?
Orient Express is offline   Reply With Quote
Old 06-30-2008, 10:08 AM   #1208 (permalink)
Excalibur's Avatar
Jeremy
I mean I don't wanna mount the ballast down in the front bumper area, I would like to have it up behind the headlight's, in the engine bay somewhere.
Old 06-30-2008, 10:52 AM   #1209 (permalink)
why is that?
Old 07-01-2008, 01:53 AM   #1210 (permalink)
Javi-Si's Avatar
Javier
subscribed waiting to order mine to use this..
Javi-Si is offline   Reply With Quote
Old 07-01-2008, 05:28 AM   #1211 (permalink)
Excalibur's Avatar
Jeremy
why is that?
So I don't have to take off the bumper to get to em if I need to change them out or do something else. Easily accessible.
Old 07-01-2008, 09:34 AM   #1212 (permalink)
WHTVTEC's Avatar
Daniel
Used this DIY in the installation of my kit. Got the same as the OP and they work great and look awesome. Thanks for the write up OE.
WHTVTEC is offline   Reply With Quote
Old 07-02-2008, 11:44 PM   #1213 (permalink)
Dan
When I turn the lights on, the driver side works perfect! BUT the passenger side will turn on VERY dim for 1 sec and shut right off! I would really appreciate some advice since I have to go to work in 9 hrs!
chiefchankton is offline   Reply With Quote
Old 07-03-2008, 12:31 AM   #1214 (permalink)
Dan
i tried the connections...I ripped everything apart and then re-assembled everything. Still nothing, so I first swapped out the bulb and installed it into the "good" ballast, it came on for a second and then shut off. Then I wanted to check out the "good" bulb in the other ballast...the SAME thing! It would come on for a second (very dim) and then shut off!!! I cant believe that I received a bad ballast and bulb!
Old 07-03-2008, 08:28 AM   #1215 (permalink)
Excalibur's Avatar
Jeremy
And you're using the same brand as the OP?
Old 07-03-2008, 08:42 AM   #1216 (permalink)
Dan
Yes, I have the same kit that OP is using. I followed his DIY to the T and that ballast/bulb isnt working. Hao contacted me very quickly and is solving this problem, no questions asked! The luck that I am having these past 2 weeks, I would be "that guy". I still recommend this company and their products to anyone! I have already referred 3 of my friends to his online store!
Thank you for the help!
Old 07-13-2008, 06:38 PM   #1217 (permalink)
sasebonian's Avatar
Jason
Thanks, OP, for this tutorial. I ended up getting a different kit, but it had the same type of setup. I too chose a 6000K kit. I mounted them in the same locations. My kit didn't come with a relay harness, but I will go w/o them for now, since my friends that have PNP HID kits for a couple of years now, don't have an issue. And if I do....well tough luck on me. I also utilized the pair of 10mm nut and bolts that the kit came with, to suppliment the threaded ones already on the car. Thanks again, OP, for pointing these out as they made the install easier.
I do want to point out for people that have the factory intake/resonator, I had already removed mine as I did a poor man's Mugen intake. If you still have your stock resonator, you may have some space issues while working on getting the ballast on the drivers side. Other than that, it was a breeze to install. I personally just lifted the car on jack stands, turned the wheel, and removed most of the fender well. Then I turned the wheel the other way when I worked on the other side. The hardest part was turning the bulbs to lock in. I didn't have any silicone lubricant, so I guess that may have helped. This took about 45mins for me to install.
Thanks again.
sasebonian is offline   Reply With Quote
Old 07-14-2008, 12:54 AM   #1218 (permalink)
Ocean's SI's Avatar
Sam
Great write up and great pics! I'm coming from a BMW M5 and the HID's on there would move up and down depending on the angle of the car...Like for example you went into a dip the lights would adjust upwards, and downward like if you were accellerating real hard and the front of the car lifted up.
The problem I have seen is that on one of my favorite turns I took in my new 08 Fa5 Si, the beam lighting the road and the turn ahead was really bouncy. It was totally annoying. At least for me. Wouldn't Hid's be even worse since they are soo much brighter?
Copied from nifty
"'By design, ALL...ALL xenon system cars (acura, bmw, MB, linc, lex) are fitted with self-leveling xenon lights. Based on the strength of the HID lights which are about 3x stronger than normal light bulbs are, how would u like to be stuck with all that power in your eyes!!!! Well anyway in response to you wondering why your M5 would need self-lev lights....sorry bud, but u'r M5 isnt any less special than the others. Its not even the M5 that is the issue here...its the company that makes the lights, whom i have no idea who it is (Is it BOSCH?) , that designs the lights like that."
Ocean's SI is offline   Reply With Quote
Old 07-14-2008, 12:33 PM   #1219 (permalink)
Admi
6000k
Atomicblue2006 is offline   Reply With Quote
Old 07-14-2008, 12:33 PM   #1220 (permalink)
Admi
6000k
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 12:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 08:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 01:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 02:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 97 03-16-2009 04:52 PM
hid installation help. StyleZ California South 14 10-22-2008 07:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-05-2007 11:36 PM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 04:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 12:14 AM
