#102 (permalink) | |
#103 (permalink) | |
Christian
Then we'll see who is "lying" here. ![]() Edit: I shall not be held accountable and responsable for the stupidity of others. Therefore, if damage might occur, I shall not be billed! =] Last edited by striker_1818; 02-25-2007 at 04:58 AM. |
#104 (permalink) | |
#105 (permalink) | |
Christian
Juvenile would be calling you an idiot and what not which is what i didnt. You're accussing me of lying for something i saw firsthand. But whatevr floats your boat man.
#106 (permalink) | |
#108 (permalink) |
Striker_1818, you sound like you feel very strongly about your statements. It would be great if you would conduct an experiment on the results of a failed HID ballast on the supply wiring of an 8th Generation Civic.
It appears that your hypothesis is that a failed ballast will cause cause damage to a cars wiring harness. Generally, your hypothesis seems to be the minority opinion because of the facts presented in earlier posts. However anyone can be wrong, so perhaps you would want to propose a testing environment that will validate your position. Include what data you plan to gather, how you will gather the data, and then conduct the experiment and post the results. Until you can objectively demonstrate your claims rather than base them on heresy, then they are just conjecture. |
#109 (permalink) | |
Christian
#110 (permalink) | |
#111 (permalink) | |
#112 (permalink) |
HID
OE: I ended buying a kit from the same seller as you but my install was not as smooth. The bulbs refused to go into the headlight socket. After examining the bulb I noticed that the base around the bulb where the o-ring is what was way too tall. I used a dremel to cut about 1/2" from the top of the base and I was finally able to install the bulb smoothly (I did clean the bulbs before installing
). Otherwise the kit was great for the price and the light output is great and the cutoff is similar to the pciture you posted. Thanks for posting...you saved me a lot of money.PS: Loved the "Produce Introduce" instructions
#113 (permalink) |
Striker, Orient you guys still at it? you guys both have conflicting information...some maybe true at both ends..but in the end if you go the plug into stock harness route, that's your choice, if you use a relay kit, that's your choice. In the end it boils down to personal choice. Some would rather use the relay like myself because it gives me a peace of mind...others use the stock harness because it cuts down on the wiring one must do.
But IMO we're all 8th gen fanatics...and should be civil to each other...constructive criticism not crushing each other with insults. But to everyone his own...that's the beauty of having a personality...you're allowed to have different opinions..but be considerate of other's opinions even if you don't agree. |
#114 (permalink) | |
Glad to hear that you are having good luck with your lamps. Your issue with the bulb not locking in easily is something that I encountered as well. The bulb base has extremely tight tolerances, and is difficult to get it fully seated. I found that simply lubricating the bulb base with silicone lubricant and using a flat bladed jewelers screwdriver the push the bulb in the last few millimeters to get past the latch did the trick. Lastly, to everyone reading this thread, I want to reemphasize that my stand on the Relay harness not being necessary is not an opinion but is rather based on hard facts. My goal in contributing to this discussion is to provide some tangible facts. The challenge facing those who are looking for advice on this issue is that because most of the retrofit kits come with a harness, the logic is that it must be used. Remember the kits are universal retrofit kits and in some vehicle retrofits the harness is useful, particularly for pre-2000 model cars. However again I must stress that the 8th generation Civic's headlight wiring is the same for both HID and non-HID cars in all markets, and utilizes a relay circuit for switching, has the same gauge wire as a retrofit relay harness has, and is fused on each circuit leg as well as the main circuit. Every 8th gen Civic owner has a HID-ready car already, no extra wiring necessary! Last edited by Orient Express; 03-27-2007 at 12:58 AM. |
#115 (permalink) |
My hid cutoff is not nearly as good as your PNP kit. Is there a difference in the bulbs b/t kits? I have quite a few flares above my cutoff line. I will try to get a picture tonight to show what I am talking about. TIA
#117 (permalink) | |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
