#1061 (permalink) |
i have a question for anyone that is familiar with this problem.... i installed my hid kit last night and they worked beautifully for the rest of the night, but today when i turned them on only one bulb was working and stay off for a couple of hours then it started working again...... diagnosis?? any answeres so that i dont run into this again??????????? btw it happened with my buddy's hid kit too so i know its not just my car
#1063 (permalink) | |
#1066 (permalink) | |
Are yours Pnp? If it is, Recheck: - Ground connectivity, - Make sure the connector from the ballast seated correctly to the oem connector, you should hear 'click' sound. Plug not seated correctly will result high voltage spark inside the connectors that can cause short circuit and burn the connectors. - Check the headlight fuses. If every connections are good, you probably have a defective hid kits. Exchange the kit. |
#1068 (permalink) |
DVS Si
anyone have any issues trying to plug in the hid bulb to the OE harness? I got the K Light kit for 9006 and the OE plug won't fit the male connector of the HID bulb.
the pins look too close together. Got it from on EBAY.
08 NHBP FA5 93 EG6 GSR-T Hondata S300 The 8th CA Squad Member#44
#1070 (permalink) | |
#1073 (permalink) | ||||
#1079 (permalink) |
Master of Magnetism
I got them from the guy the OP recommended on eBay. PM me if you'd like his eBay seller name.
Installed them tonight, they look awesome, I'm totally satisfied. Went with 5000K. Will try to take some more pics tomorrow. ![]() Last edited by E. Honduh; 05-01-2008 at 12:10 AM. |
