#1042 (permalink) | |
The question I have with mounting the ballast where the green arrow points to is this: Won't there be any water coming from under the headlight directly into the ballast therefore damaging it? If so, should we not cover the ballasts in plastic or something? Regarding the glare of the headlights that some people experienced, I believe the problem is with the fact that their bulbs are not in properly. One of my bulbs did not go in properly and it's a bit sideways in the housing. As a result I get a horrible glare. Will need to fix that later on today. |
#1043 (permalink) |
07Ex, goback to page 52.
Take a look at the pictures that I posted. I couldn't find any other better place to mount the ballast. I found a spot inside the engine area, but concerned of the direct heat from the engine block. To sit the bulb properly try to use OEM O-ring. All I know that the ballast is waterproof (experiments done by some manufactures ... I forgot which company but they dip the whole unit inside an aquarium tank with lights on). |
#1045 (permalink) |
That looks like a good alternate location.
So it looks like on the non-hybrid civics, there is an air box or something that is bolted in the position that I used to mount my ballast? What is that black box there under the bulkhead? ![]() One other tip, is that if you do mount your ballast horizontally, squirt some white lithium grease in the 12 v connector shell of the ballast to further waterproof the connection. |
#1046 (permalink) | |
#1048 (permalink) | |
I had no problems with installation in my 06 Sedan and I am very happy with the results. |
#1051 (permalink) |
Dont Mess With This Zohan
Nichuma Ben Gabriel Ha Levi
![]() Click Sig for Details on the Wreck, it just gets worse. DIY HFP Front Lip Overlay CHEAP! | DIY HFP Side Skirt installation DIY AUTO Shift knob Removal | DIY E-Brake Trim removal License = SUSPENDED Days left = 4
#1057 (permalink) | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 12:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 08:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | ||||
