#82 (permalink) |
The relay harness is unnecessary
The 8th Generation Civic's lighting wiring is more than capable of supporting the demands of this HID retrofit kit.
The relay wiring harness is not necessary! However, if security blankets, and monsters under the bed are a part of ones life, then by all means, install the relay. Being scared of the unknown is the american way!
#84 (permalink) |
karlitO
theyre shipping from Guangzhou city of china..
and they now have 100% feedback after 370 something transactions.. i might think bout buying from them when i decide to go HID.. btw.. OP, youve had the HID's since November.. how are they holding up?
#85 (permalink) |
My friend helped my cousin install these on his car. We couldnt get the bulbs in properly and instead of loosening the screws, he just used a dremmel and shaved down the edges to have it fit properly. Also, as stated before the relay are not needed
#88 (permalink) | |
#89 (permalink) |
Gordon Jackson
I must a fool then because when did my last two cars I used two relays each fused independantly, One for the left and one for the right. My thinking is that if the relay fails or the fuse blows on either headlight, I still have the other headlight operating till I get home and can check the circuits.
#90 (permalink) | |
![]() Modern cars, including the Civic are not only fused for the main lighting circuit, but each individual lamp wiring leg is redundantly fused for exactly the reason that you state. You simply duplicated something that was already there. Your owners manual can be very enlightening reading, if you choose to do it. |
#91 (permalink) |
![]() ![]() Join Date: Feb 2007
Great write up, this is the guide I used to figure out how to put my HID's in a few months ago.
Only thing different is, I placed my ballast on a bar that has a hole in it (which seems like it was perfectly made for mounting a ballast to) seen in this picture. This spot is exactly the same on both sides of the car and my kit came with a mounting bracket that allowed me to screw it to this hole. ![]() Mine also upon turning on, draws 7.5A for the first 3 seconds, then at only 3A while running. I know this is what the modexpress company just says, and I have not tested this to prove it, but this is why my kit does not need an upgraded harness as well (but I suppose this could all be a lie). |
#95 (permalink) | |
Kevyn
i guess i'll go with the driver side too, or whatever is convenient. |
#98 (permalink) | |
Christian
A relay harness is not necessary but for safety precautions it is highly recommended.
#99 (permalink) | |
#100 (permalink) | |
The stock wiring harness is in-fact superior to an add-on relay harness, because of redundant fusing, and the conservative way that each light is fused independently. 9 out of 10 times a reported foul-up is directly attributable to the person who modified their car incorrectly. |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
