My Civics HID DIY Installation - Page 4 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 01-18-2007, 09:41 PM   #61 (permalink)
Originally Posted by Orient Express
The high beams seem to be fine. I retrofitted the high-beams to PIAA Xtreme white plus lamps. Most of our driving with this car is Urban, so there is not much chance to use the high-beams, but when we do use them they are much better than the stock Sylvania bulbs, especially in the rain.
Here is the link to the Hella H11 foglight bulbs. Note that the "each" in the order guide means a pair, not a single bulb.
Thanks. what i meant about the high beams though, is that when u have your low beams off, just DRL's, and you flash the high beams..
do your HID low beams come on also? or just the high beam? i thought it would be a problem because the hid's need to ignite, and i thought it's possible that it ignites every time u flash your highbeams creating a problem (shortening the life of the hid kit?)
Old 01-18-2007, 10:13 PM   #62 (permalink)
Tim
Tim's Avatar
Yes, the lows come on when you flash your highs. And yes, there is a risk of damaging the bulbs if you were to repeat this often.
Tim is offline   Reply With Quote
Old 02-14-2007, 11:57 PM   #63 (permalink)
Jonas
I ordered this kit and arrived after 5 days. I live in Canada btw and im surprised that no tax was charged to me.
So far, Im very happy with it.. the colour, light output, etc, but im just concerned in one thing.. When I turn the lowbeams on, it gives out a sudden burst of flash very fast, and then dims a bit for about 2-3 sec before it gives out the normal light output. Is this normal?
aiz121 is offline   Reply With Quote
Old 02-15-2007, 12:04 AM   #64 (permalink)
gbae007's Avatar
^ Normal with all HIDs. Don't worry about that.
Old 02-15-2007, 12:40 AM   #65 (permalink)
iVTEC's Avatar
That would be normal HID start-up.
iVTEC is offline   Reply With Quote
Old 02-15-2007, 03:04 PM   #66 (permalink)
wait.. so let me get this straight... you installed a PnP HID kit into your stock civic reflectors, after 2 months time the bulbs colour-shifted and so the beam pattern went from this:
Credit where it is due for this image:
to this?
ElvaSoShexai is offline   Reply With Quote
Old 02-15-2007, 03:47 PM   #67 (permalink)
Jonas
Thanks! Thats a relief!
Old 02-15-2007, 05:41 PM   #68 (permalink)
striker_1818's Avatar
Christian
Originally Posted by ElvaSoShexai
wait.. so let me get this straight... you installed a PnP HID kit into your stock civic reflectors, after 2 months time the bulbs colour-shifted and so the beam pattern went from this to this.
camera effect + wall color = different output.
Remember...all true HID's colorshift (4,100K - 4,300K)
striker_1818 is offline   Reply With Quote
Old 02-15-2007, 05:43 PM   #69 (permalink)
so which pic would it actually look like in real life? cause the 2nd pic actually makes it look really decent
Old 02-15-2007, 05:49 PM   #70 (permalink)
gbae007's Avatar
^ Assuming it's a white wall, the second photo is more like OEM hids. The first one is messed up by the camera's AWB.
Old 02-15-2007, 05:51 PM   #71 (permalink)
Christian
2nd picture...
However, colorshifting after 2 months of use
Old 02-15-2007, 11:26 PM   #72 (permalink)
lexusguy's Avatar
1st pic doesnt look 6000k more of a 3000k-43000k
lexusguy is offline   Reply With Quote
Old 02-16-2007, 06:23 PM   #73 (permalink)
Orient Express's Avatar
So let me set the record straight
As the originator of this thread, I wanted to provide the context of these photos.
There were a few of you that were interested in beam patterns, and were interested in what the pattern looked like with a HID conversion using the Civic reflectors.
I had received a request to see what a wall reflection looked like. I did not have any photos at the time so I simply did what those who were interested should have done, i.e. I did a search of the forum archives, and came up with this photo.
Please notice that in the original post, it has a credit to the original photographer.
Later, I actually got around to taking a photo of a Civic headlight pattern wit the HID conversion that I did, and this is what this photo is.
If you are looking for a representative photo of color, then use this one.
The bottom line is that they are from 2 different cars, cameras, environments, and photographers. That is why they look quite a bit different. There is no claim that the conversion color-shifted etc. or that this is a before and after series of photos.
Orient Express is offline   Reply With Quote
Old 02-17-2007, 02:30 AM   #74 (permalink)
dorkiedoode's Avatar
Kevyn
how was it for you guys to put the bulb in the housing? seems as if it won't go all the way in.
dorkiedoode is offline   Reply With Quote
Old 02-17-2007, 02:47 AM   #75 (permalink)
Christian
I believe most people use "force" and "pushed the bulb in" with firm pressure and lock it in as u do with a normal 9006 bulb and that should do the trick.
Old 02-17-2007, 03:18 AM   #76 (permalink)
Exeon's Avatar
asdfghjkl
the passenger should fit with ease, but the drivers side, I used some oil around the housing where it locks into headlight
2 months and still working fine
Exeon is offline   Reply With Quote
Old 02-17-2007, 04:35 AM   #77 (permalink)
Kevyn
what lubricant should i use? you think wd40 would work? i want something that can be remove later on because i am afraid it might dry up and will be harder to take out next time.
Old 02-17-2007, 10:31 AM   #78 (permalink)
mishima8's Avatar
There are three screws you can loosen to give you more space. Either loosen or remove (careful not to lose the screws) and the insert the bulb. Once they are in reattached the screws and bezel and you should be good.
mishima8 is offline   Reply With Quote
Old 02-17-2007, 05:09 PM   #79 (permalink)
Kevyn
(image by Orient Express)
such as those?? that would make things much easier.
Old 02-21-2007, 06:57 AM   #80 (permalink)
hey there, just wanted to say awsome write up on the HID install. I orders this kit and had it a few day later. It has all be installed and working amazing. I had a quick question about the relay install.
Ive installed the relay,
1) the positive and negative are hooked to the battery
2) the orignial headlight wire is hooked onto the harness socket
3) the 2 wires left in relay are plugged into each of the ballasts.
Im assuming i did this right as everything is turning on.
Does this seem correct??
thanks
naheedv is offline   Reply With Quote
Instalação de xenon no farol baixo This thread Refback 09-14-2011 05:01 AM
HID: How much on an 8th gen??? This thread Refback 09-10-2011 03:07 AM
07' SI, HID install Q's... - HondaCivicForum.com This thread Refback 09-02-2011 06:02 PM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 100 11-11-2010 01:49 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
