My Civics HID DIY Installation - Page 31 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 10-31-2007, 05:55 PM   #601 (permalink)
Bandit03's Avatar
i do what i want
i got my dome lights from superbrightleds.com , as far as those go there is already a DIY i dunno what other lights there are to replace as far as the interior goes? How To: LED Festoon map lights
Bandit03 is offline   Reply With Quote
Old 10-31-2007, 05:57 PM   #602 (permalink)
tda1337's Avatar
Rick
OH i ment exterior and interior, they make it more confusing than it has to be so i want to make it more clear as to where and what is available!
tda1337 is offline   Reply With Quote
Old 10-31-2007, 08:28 PM   #603 (permalink)
Originally Posted by Bandit03
i actually had 10000k bulbs before and they were a deep bluish purple, they had horrible output however every sign and reflector did light up, same now with my 6000k, way better output but not really impressed compared to stock so i may go lower
How are you NOT impressed with the 6000K? They provide 5x more light than my stock bulbs! U must be crazy! lol.
CDRoot is offline   Reply With Quote
Old 10-31-2007, 09:05 PM   #604 (permalink)
Bandit03's Avatar
i do what i want
haha i dont know i mean they are definetly way better than stock, but they just dont do much for me, i feel like with stock i could see much further down the road, i guess i just had high expectations so i may go to 5000k or 4300k
Old 10-31-2007, 09:14 PM   #605 (permalink)
tda1337's Avatar
Rick
which makes sense, less light output, im gonna go with 6000k cause its still gonna be plenty more output than halogens, so meh
Old 10-31-2007, 09:17 PM   #606 (permalink)
"haha i dont know i mean they are definetly way better than stock, but they just dont do much for me, i feel like with stock i could see much further down the road, i guess i just had high expectations so i may go to 5000k or 4300k"
Maybe you should adjust the headlights so they project farther.
Old 10-31-2007, 09:20 PM   #607 (permalink)
Bandit03's Avatar
i do what i want
i honestly have no idea how to do that and i dont wanna mess anything up or aim them too high and have to deal with the cops
Old 10-31-2007, 10:45 PM   #608 (permalink)
tda1337's Avatar
Rick
i honestly wouldnt bother, because they should be already aligned, have a shop do it if it needs it
Old 10-31-2007, 11:06 PM   #609 (permalink)
striker_1818's Avatar
Christian
Originally Posted by tda1337
any website u go to will have their own specs, each company has different specs because their bulbs and ballasts are fidderent
actually they make up specs for sales. Same way they show their 4,300K to have 3,400 lumens when an 85122+ which is rated at 4,200K will give you twice as much light as their 4,300K. I don't want to see charts. I want detailed information
yea but i mean i saw an audi SUV the other day and his lights were so bright i couldnt even see the frickin road in front of me and i know for a fact that they are stock like that so theres no way a cop could single me out, i havent had any flashes to this day but im just sayin
its easy to spot pnp kits vs oem
striker_1818 is offline   Reply With Quote
Old 11-01-2007, 12:24 AM   #610 (permalink)
tda1337's Avatar
Rick
um so do i , show me where u got that info from lol
cause not too many companies i know of make 4200kelvin bulbs lol
a) every bulb and ballast is different and they make up spec sheets based on simple tests with simple machines or equations
b) some ballasts use 18,000Vs some use 25,000 volts, why would u thing a ballast and bulb at 18,000volts with a color temp of 4300k would have the same lightoutput as the 25,000 volt ballast/bulb with 4300 kelvin temp? The noble gases used are also VERY different! its like LEDs man, there are Nichia, Luxeon and cree, but they all do very different chemicals to get to their final result (fyi they are named after their inventories)
The light out put depends on many variables:
1) Voltage
2) Wattage
3) resistance
4) chemicals!!!! (most important, this includes noble gases)
5) glass properties
6) electrode properties
If you can show me, some testing sheet, that shows that an 8000 kelvin bulb from the same manufacturer as a 4300kelvin bulb has more lumens... please show me
until then man... its all talk, i can show u every website thats advertising department places that its not brighter! Go to any ebay ad, go to xenondepot.com
they use ratings given to them by the manufacturer (yes they doctor up pics and etc.) but most of the times the ratings are right on!
if they lie about that stuff, law suits can happen
Old 11-01-2007, 01:10 AM   #611 (permalink)
bludragon06's Avatar
Dave H
Ok i ran into a problem...
So I am working on the drivers side putting in the set. I finally get the bulb seated loosening the plastic peice that holds the bulb in plug everything in and I see the bulb flicker really fast and here what sounded like arcing and then light goes out. I thought I french fried the headlight wires. Found it was a fuse. Replaced the fuse unplugged everything and changed bulbs and got that arcing and flickering again. So I plugged the the bulb that I changed to and plugged it into the other ballast and bingo. Let there be light. I tried the first bulb in the good ballast and nothing. So I emailed the guy with the problem. So we will see what he says. He had great fast shipping and kept in touch very well. Lets see how customer service is. I have one side in and the halogen in on the other side. Looks really wierd.
bludragon06 is offline   Reply With Quote
Old 11-01-2007, 01:43 AM   #612 (permalink)
Christian
1) Voltage
2) Wattage
3) resistance
5) glass properties
I guess you really want to get pwnt:
1)
Osram Xenarc D2S rated at 4,250K bulb
Lumens: 3,200
Source? Spec sheet: Link (Page 4 and 5)
2)
Philips 85122 D2S rated at 4,100K
Lumens: 3,200
Spec-sheet:
3)
Philips Ultinions rated at 5,800K
Lumens: 2,400
Spec-sheet:
4)
General Electrics D2S HID bulb rated at 5,100K
Lumens: 2,500
Spec-sheet:
5)
General Electrics 5874 rated at 10,000K
Lumens: 1,850
Spec-sheet:
Again, retailers such as XenonDepot do not test the bulbs so their website based charts are way off.
Old 11-01-2007, 08:24 AM   #613 (permalink)
tda1337's Avatar
Rick
oh i was under the understandment that u thought the2500k estimate was too little lol oi vey
Old 11-02-2007, 11:21 AM   #614 (permalink)
basing on what i read everywhere ....
4300K is OEM color for the likes of BMW and gives more lumens ....
3000K very yellowish and best for off roads..... wont do well with street lights
6000K white to bluish ..... balance of function and "fashion" hehehe. But for city use this may also work nicely (well i think)
just had a 3000K HID installed in my civic .... am loving them since they reflect nicely on asphalt roads ..... and without adjusting the headllight assy. alignment yet oncoming cars seems not affected with the light ....
my only gripe is that the right side seems to be poorly illuminated. must be the alignment ......
ment is offline   Reply With Quote
Old 11-02-2007, 12:23 PM   #615 (permalink)
Orient Express's Avatar
Depending on where you live
3000K bulbs may get you stopped by your local law enforcement. Yellow colored headlamps are illegal in most states for on-road use.
Orient Express is offline   Reply With Quote
Old 11-02-2007, 12:39 PM   #616 (permalink)
jackolee's Avatar
okay so Izzy was talking about if i dont have the hid harness installed and if blow my lights all the wires will get blown so i got worried and installed the harnesses i got with the kit while i did my foglights
and after i did so i sat in the car turned on the lights they were all good just like before
but when i turned them off i heard this click sound like the sound of a spark or something
can someone tell me what that is?
jackolee is offline   Reply With Quote
Old 11-02-2007, 11:32 PM   #617 (permalink)
tda1337's Avatar
Rick
um, sounds like a short, or the fuse blew lol
u screwed something up lol
this is why orient and me both say not to use the relay harness (the wires on the civic are thick enough to handle the load, in fact they are fused the same)
Old 11-03-2007, 02:31 AM   #618 (permalink)
Christian
6.5ft 18ga
Old 11-03-2007, 02:52 AM   #619 (permalink)
jackolee's Avatar
.....it works tho....so does that mean something still blew???
ugh dammit i dont feel like taking off the bumper again... grrr....
so your saying th stock wires are good enough???
grrrr i guess ill take it out while im at work or something.... grrr..
6.5ft 18ga
what??? i dont understand what your saying sorry
Old 11-03-2007, 03:00 AM   #620 (permalink)
Christian
Here is what i discovered.
The length of our wiring for the 9006 is a long 6'-6"(6.5 ft) 18 gauge wire.
This is for reference to you: 100 watts = 16 amps.
And here is what you should know. What type of current and wiring gauge can handle what:
Instalação de xenon no farol baixo This thread Refback 09-14-2011 05:01 AM
HID: How much on an 8th gen??? This thread Refback 09-10-2011 03:07 AM
07' SI, HID install Q's... - HondaCivicForum.com This thread Refback 09-02-2011 06:02 PM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 100 11-11-2010 01:49 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
