LinkBack (4) Thread Tools Display Modes
Old 11-30-2006, 11:57 AM   #41 (permalink)
Orient Express's Avatar
Originally Posted by bluetroll
i couldn't get the driver side bulb to fit... it wouldn't lock!
Did you try putting some silicone lubricant on the base and on the O ring?
The other trick is once you have the bulb twisted in as far as you dare by hand, take a mid-sized jewelers flat bladed screwdriver, and place the tip against the base in the socket to push it the last millimeter or so. You will hear the retaining latch click when it is in all the way.
I agree that the tolerances are very tight, and the bulb base can bind, that is why the lubricant helps. Don't spray the lubricant directly on the bulb, as you will probably get it on the glass, but rather spray some on a Q-tip and dap it on the bulb base fingers, and the O ring. Another trick is to take a hair dryer and heat up the housing bulb receptor to make it expand a little, then put in the bulb.
Orient Express is offline   Reply With Quote
Old 12-03-2006, 02:25 AM   #42 (permalink)
Exeon's Avatar
tailgate the huge wing
i'm really tempted to buying one of these sets, could you take a pic on a road/street with the car at a stop
Exeon is online now   Reply With Quote
Old 12-03-2006, 03:34 AM   #43 (permalink)
Avenger's Avatar
Rob
My drivers side on my PnP kit didn't lock in properly (as well as the passenger side) either...........meh, it still seals fine
I have 8000k HID's. Had em for 3 years now, just pulled them from my Intrepid when it went into storage, and put em into the Civic. Never got pulled over by the cops, and I've only been flashed a handful of times.
Love em.
Avenger is offline   Reply With Quote
Old 12-03-2006, 03:46 AM   #44 (permalink)
n00b retro whore
ethlar's Avatar
after hearing most peoples good experiences with these kits im actually going to order a set in the next few days, im torn between 4300k and 6000k, ASM LX sedan if it makes a difference
Old 12-03-2006, 05:16 PM   #45 (permalink)
:beer:
Mikey6p's Avatar
Mukey
go 6000
Originally Posted by Celcius View Post
Sorry for being off-topic but is that a picture of a **** stained urinal divider as your avatar?
Mikey6p is offline   Reply With Quote
Old 12-04-2006, 04:47 PM   #46 (permalink)
Exeon's Avatar
looks like i'm ordering the 6000k kit tonight
Old 12-04-2006, 05:04 PM   #47 (permalink)
vtloki's Avatar
Jeffery
Ordered mine 2 days ago. Can't wait to get them, and install them. I also ordered 6000K, and it was this post and a few others that had such good experience and results with this kit, I just had to get it. $160 for the HID look and performance is awesome.
vtloki is offline   Reply With Quote
Old 12-04-2006, 05:23 PM   #48 (permalink)
striker_1818's Avatar
I Love Kristina
if u want this cheapo kits then don't go past 6000K if u want decent light output on the road. On the 1st page, he posted a night picture of his lights against a wall. If you're too lazy to look then here's a quote
Originally Posted by Orient Express
Credit where it is due for this image:
Do you see the hotspots above the cuttoff line? Those are the brightness that can blind you temporary and cause you to get into an accident if u are of course driving on the opposite direction.
The light output on the ground is not really good hence halogen bulbs such as the new sylverstars which have a wider output on the road can get u the same results and for 40 bucks a pair with less glare.
And to finish this off, even though I'm not a fan of hid kits, i can see the effort you put into your DIY thread and hey man thumbs up for your effort and easy to follow DIY!
striker_1818 is offline   Reply With Quote
Old 12-04-2006, 05:46 PM   #49 (permalink)
n00b retro whore
ethlar's Avatar
If you look at the halogen beam pattern vs that one there those hot spots are there too, the housings are designed to throw some light up to illuminate reflective road signs and reflectors on other cars and trucks. The hotspots do become somewhat more pronounced with the brighter hid bulbs but for the most that not a horrible beam pattern. I ordered 4300k btw, figure it will colorshift towards 6000k some and il still be happy.
Old 12-04-2006, 06:02 PM   #50 (permalink)
I Love Kristina
after 100 hours or so your bulbs will colorshift. If you drive a civic(stock) you can see the beam pattern which is pretty good and a lighter to no hotspots above the cutoff line. Also, they have aim-ed the headlights to the ground which makes it ridiculously difficult to see road signs.
but yeah...just picked up a set of tsx projectors =D
Old 12-05-2006, 01:34 AM   #51 (permalink)
bluetroll's Avatar
NBP Si
has anyone tried installing these without removing the wheels?
bluetroll is offline   Reply With Quote
Old 12-05-2006, 02:11 AM   #52 (permalink)
Jew Crew
GETxERxDONE's Avatar
Nick
you take out the battery for the drivers side..but your screwed for the passenger side. unless you just turn the wheel to get more room in there
GETxERxDONE is offline   Reply With Quote
Old 12-05-2006, 04:00 PM   #53 (permalink)
bluetroll's Avatar
NBP Si
cool... i'll try tonight... thx.
Old 01-04-2007, 07:41 PM   #54 (permalink)
As an update to this HID story, the lights have been in for over 2 months with absolutely no problems, and not one on coming car has flashed me, suggesting that the light pattern is not bad for oncoming traffic.
I have also installed the fog light kit and have upgraded the high beams with PIAA 4000K 60w bulbs. I also upgraded the fog ligh bulbs with Hella Extreme Yellow bulbs.
Old 01-04-2007, 07:53 PM   #55 (permalink)
gbae007's Avatar
Bump for an excellent thread.
Old 01-18-2007, 06:22 PM   #56 (permalink)
Actual Civic reflector HID retrofit light cutoff photo
I finally got around to taking an actual photo of the light pattern of this HID kit that I put in my Civic sedan. I also have a photo of one of my other cars that has Bi-Xenon lights for comparison.
1st the HID Kit shining on a wall from 20 feet:
Next the Bi-Xenon lamps from the same distance:
While the upper cutoff is not quite as sharp, the overall beam pattern of the reflector based HID retrofit is very close to a Bi-Xenon projector HID system. There is very little if any spurious light on these reflectors. Notice that the light color is whiter than the Bi-Xenon lamps.
While I won't bore you with what kind of car the Bi-Xenon lights are on, the replacement cost of each those headlight assemblies is $3800. My $165 HID retrofit is probably 95% as good as the high-priced units, so I think that it is a very good investment. It is a shame however that there are not cheaper or easier solutions for Civic projector headlights.
Old 01-18-2007, 06:33 PM   #57 (permalink)
Tim
Tim's Avatar
That is an excellent comparison photo! It won't bore me. Come on. What car are those bi-xenons on?
Your photo does help to see the difference in dispersion of light. The projectors casts light evenly, widely, and without the hotspots in the center of the field of vision. The reflector results aren't half bad though. Good info!
Tim is offline   Reply With Quote
Old 01-18-2007, 08:32 PM   #58 (permalink)
good stuff OE, i'm going to get one soon if the HIR bulbs aren't as good as i expect.
i'm just curious though, how does your highbeam work? because when i use my highbeam when my lows are off, it flashes both the highs and lows. How does it work with HID's now?
oh yeah also, where'd you buy your hell bulbs from? thx
Old 01-18-2007, 09:01 PM   #59 (permalink)
The high beams seem to be fine. I retrofitted the high-beams to PIAA Xtreme white plus lamps. Most of our driving with this car is Urban, so there is not much chance to use the high-beams, but when we do use them they are much better than the stock Sylvania bulbs, especially in the rain.
Here is the link to the Hella H11 foglight bulbs. Note that the "each" in the order guide means a pair, not a single bulb.
Lastly here is the car of mine that has the B-Xenons:
Old 01-18-2007, 09:33 PM   #60 (permalink)
Tim
Tim's Avatar
haha what a "boring" car. If by boring, you mean beauteous.
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 98 08-18-2009 03:41 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
