#562 (permalink) | |
#563 (permalink) |
I just tried them out tonight, (6000K kit) and they are soo bright and beautiful! Pnp kits work really well with our cars and I dont think anyone will flash us because the front ends of our cars are soo much lower than other cars, so therefore our headlights are placed lower to the ground as well. Just compare the height of ur headlights with other cars - u will see! Dont be such scardey cats and just get this kit! I had blue bulbs upgraded from stock ones before, and there is like 5x more light now...prolly 10x more light than stock bulbs!
You dont need to spend 1000 bux for a retrofit. If u want brighter, clearer vision, then get the pnp kit. If you want to be fancy smancy, then go ahead and get retrofitted. My 2 cents. |
#565 (permalink) | |
#566 (permalink) | |
#567 (permalink) | |
![]() Not accepting facts is not healthy man. Just admit there's glare lol If you've never had HID's before, then i'd understand where your answer is coming from but come on
#569 (permalink) |
I do agree that the light output is better with these PnP kits and our housing don't produce as much glare as other cars, but it's not to say there isn't glare. There are still a ton of hot spots and the distribution of light is still not going to compare vs. a retrofit.
#570 (permalink) | |
#571 (permalink) |
I finally got mine installed yesterday. *second try*
The first time i tried to install it with the wheels on. it seem impossible since theres no room to work with. So i gave up. I just took my car to canadian tires since i worked them before. I jacked up the car and remove the wheels. Made things much easier. It took about 1 hr 1/2 to finish. Results were Good.
#572 (permalink) | |
#573 (permalink) |
Considering buying the kit off of Ebay. Not sure if I want 4300k, 5000k, or 6000k. I don't want to sacrifice any light output from stock (I'd prefer an increase in light output, but I also want that nice "HID" look.
Is the 4300k my best bet? I read somewhere around page 15 or so that a lot of people with the kit have had bad ballasts/etc that need to be replaced. Can anyone attest to this? I want something that is going to be reliable as well. Thanks! |
#574 (permalink) | |
Also if u have halogens, and one is an improvement over light, most people suggest 6000k cause of the blueish tint (if u had an LED flashlight u would understand) Im getting 6000k cause the blueish tint will go with the blue everywhere in my car 5000k gives u a pure white, and 4300k gives u a halogen like white, but MUCH brighter, lumen output on 4300k is about 3-400 lumens more, so u get more light outta the lesser kelvin temp! its really up to u man, is it for looks, functionality or both? (for me both!) |
#575 (permalink) | |
i've tried and D2R give the best result but no kit comes with a D2R setup:Halogen on the left, rebased D2R on the right: ![]() Yielded better results than expected due to the built-in shield on the bulb. Still no match against a retrofit though. D2R produces less lumens than D2S bulbs. |
#576 (permalink) | |
#579 (permalink) | |
WHITE = LEGAL. BLUE = ILLEGAL |
#580 (permalink) |
I bought the 6,000K kit second handed from someone and the kit has about 1 year of usage on it. I can definitely tell you the bulbs have gotten a bit bluer over the time span I've had them. The likelihood of you getting hassled by cops is more probable as you move away from 4,300K, not the other way around.
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 12:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 08:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 01:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 02:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 77 | 09-11-2008 02:06 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-05-2007 11:36 PM |
| hid installation help. | StyleZ | California South | 8 | 11-20-2006 09:14 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 04:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 12:14 AM |
