#461 (permalink) | |
Christian
Blue light is passable and has less lumens. That basically means there will be less light output. 6,000K on the other hand has more white and a tint of blue. Your eyes will love blue more and you will notice it from a great distance, however, there will be more glare because you have more lumens. However, if you go down the kelvin temperature, you won't notice much a subtle white or yellowish color because your eyes will catch more "blue" tuff out there on the road rather than yellow or subtle white. Intense white/blue/purple on the other hand is a no-no but of course, the less intensity, the less your eyes will be bothered by them.
#463 (permalink) |
I thought it was time to provide input on the install. I installed the 6000k kit in my Civic about 1.5 weeks ago. I did not use the relay kit. So far, the lights start up normally with no flicker. Light output and pattern are very good. I needed this update because I have cataracts in both eyes, and the cataracts have not progressed to the stage my insurance will cover the surgery. I have to drive to work in the dark every morning. So, any improvement over stock lighting is helpful and safer for me.
Thanks to OE for the DIY and to Striker for help! |
#466 (permalink) | |
![]() Join Date: May 2006
The biggest downfall is that you lose the ability to flash someone because HIDs take a bit of time to start up. Also, you don't tend to use high beams for a very long time like you do with high beams. Turning them on and off constantly would wear them down quite a bit. |
#474 (permalink) |
my 6000ks are also doing well, i love the color.. the brightness is good, i wish they would reache a little further, but i dont wanna aim them up because of the whole blinding thing... so... im satisfied and didnt spend 1k on a projector retro
#475 (permalink) | |
#476 (permalink) |
i do what i want
yea im having the same problem, i cant manage to get the bulb in all the way, i read people have cut to make it fit buti dont have the tools for that so its basically just wedged in there for now, but other than that i love them
#479 (permalink) |
I would still try getting some lube in there. If that doesn't work, slowly sand down the area that is getting caught - it should be fairly obvious as that part of the bulb will be contact damage. Otherwise, if the bulb isn't seating in the socket firmly, your lights will be bouncing everywhere and possibly fall out.
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
