#401 (permalink) | |
Christian
OEM harness uses 18ga wire and has a fuse to protect them. Some Ballasts need a huge amount of power to get them to work but some don't. That's why a relay harness was created. It is universal for any type of ballast and provides protection with a 14ga wires and a relay. |
#402 (permalink) | |
#403 (permalink) | |
Because the flicker happen at the same time on both sides, I don't think I have 2 bad ballast that cause 2 flickers at the same time!!! Bad relay? I think you are wrong and right at the same time!!! Wrong, because I didn't use the relay harness. I just plug-n-play. Right, because the OEM harness has relays... and maybe it is the car's circuit that causes this issue. Or maybe the multiplexer. When we turn on the HID, the warm up period sucks a lot of juice... Maybe the harness is able to support this.... Maybe the multiplexer or an other part of the circuit has difficulties. I think that using the relay harness is a safer way. |
#404 (permalink) |
If this retrofit is the typical Chinese kit, then the ballast startup surge current is less than 8.5 amps. In that case a relay harness will have no effect.
Have you hooked up a meter to the lamp circuit to see if there is a voltage drop associated with the flicker? Also is the flicker timing consistent? i.e, can you time it, and it happens at some fixed time every time after the lights are turned on? Does it happen when the car is cold, or warmed up or both? Is the air-conditioner state have any effect? Do you have fog lamps? Are they turned on or off? While I have not seen this flicker first hand, I would suspect that since it happens on both lights at the same time that it is not the ballasts or lamps at issue, but rather something else on the car that is drawing a high current. |
#405 (permalink) | |
Sometime , the left lamp flicker 2 seconds before the right one, sometime the right lamps flicker first... sometime they flicker in the same time. But it always happen about 2 minutes after I turn them on. And then, I can ride 1 hour, 2 hours, 3 hours.... they never flicker again... until the next cold start up!!!! |
#406 (permalink) |
I take it then that it only occurs after a cold start-up of the car? Does it do it after the car is warmed up and has sat for a while? (like you went in to a store or something like that?) How long does the flickering last?
Does it matter if the A/C is on or off? Do you have the stock radio? |
#407 (permalink) | |
No! I mean a cold start-up of the HID. Here is a situation: I start my car, turn on lights, 2 minutes later they flicker one time, during the ride to my parents (35 min), no more flicker. I stay 10 min with my parents, restart the car, and come back home. 2 minutes later, they flicker one time. No more flicker until I turn off the lights when I'm arrived! It's always the same pattern. No a/c, stock sound system. |
#411 (permalink) |
i do what i want
i just got my kit in today and am prolly gonna install it tomorrow morning, im obv. not gonna bother with the relay harness but what are the 2 capacitors for and do i need to use them?
#418 (permalink) |
i do what i want
this is the kit i got with everything it came with
[img=http://img521.imageshack.us/img521/2368/cimg0818uw8.th.jpg] [img=http://img521.imageshack.us/img521/4416/cimg0819sg7.th.jpg] [img=http://img521.imageshack.us/img521/9459/cimg0825tf3.th.jpg] [img=http://img521.imageshack.us/img521/3716/cimg0826et4.th.jpg] [img=http://img521.imageshack.us/img521/4161/cimg0827fp9.th.jpg] |
#420 (permalink) | |
and how long did it take for you to get your tracking number, because he hasnt sent me anything yet? |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
