#382 (permalink) |
That is not a problem, but a characteristic of HID lamps. Do a search on how HID lamps warm-up and you will find that it takes 4-6 seconds for a HID bulb to become fully functional, and the flashing you describe is part the warm-up transition.
#384 (permalink) | |
The owner's manual for my 2006 Civic EX and the fuse in the panel states the headlight low main fuse is 20 amp, and the fuse in the panel is 20 amp. However, I am curious about the relay kit shipped to me. The relay is rated at 40-amp max, but it was shipped with a 20-amp fuse. I know that someone out there has the same relay kit that I do. I wonder what fuse is installed in the line going to the relay. Thanks! |
#385 (permalink) | |
Christian
1)malfunction drawing less power thus either not working at all or making the bulb flicker 2) malfunction drawing more power and
#386 (permalink) | |
Thanks! |
#387 (permalink) | |
Christian
#388 (permalink) | |
I did a real retrofit with bi-xenon projectors/ballast from a E55 mercedes on my last car. And I installed it with home made harness and relays because in this case, a plug-and-play is impossible. So I know how HID operate. I know that the warm up time is a couple of second. But why do you think my lamps flicker about 2 MINUTES after the warm-up??? They flicker like voltage drop.... and after, no more flicker for hours....
#390 (permalink) |
installation went well... taking off the wheel well liner/jacking up/putting on stands and taking off the wheels was the majority of time spent... the actual lighting part is pretty quick... the OP shows very good places to mount the ballasts
i like them, they're pretty and bright havent driven yet or seen cutoff though (dad's mustang was parked right in front of my car in the driveway)
#391 (permalink) |
Quail Man!
Nick
nice glad it went smoothly. hopefully mine will too! one question.
is the place you and the OP mounted the ballasts accessable if i just take the bumper off? because im going to clear my headlights at the same time so im just gonna take off th bumper. thanks |
#393 (permalink) | |
worse case scenario you have to take your wheels off and break those damn liner clips
#394 (permalink) | |
Unsurprisingly, nobody want to answer the question??? ORIENT EXPRESS, STRICKE1818 where are you????
#395 (permalink) | |
Christian
bad/loose ground will cause your lights to flicker. Same exact thing as when you grab a small bulb, wrap it around with a wire, then below it, facing upwards, add to AA batteries one on top of the other. then, from the wire you had all wrapped around the bulb, make that touch the bottom of the 2nd battery. Your light will turn on. If it doesn't (not making connection) your lights will turn off. if it's not a solid touch, then your bulb will flicker. |
#396 (permalink) | |
I understand what you say... But the flicker happen only one time, 2 minutes after I turn my lamps on! For the rest of the time, they doesn't flicker anymore!!! |
#397 (permalink) | |
Christian
#400 (permalink) | |
Because the flicker happen at the same time on both sides, I don't think I have 2 bad ballast that cause 2 flickers at the same time!!! Bad relay? I think you are wrong and right at the same time!!! Wrong, because I didn't use the relay harness. I just plug-n-play. Right, because the OEM harness has relays... and maybe it is the car's circuit that causes this issue. Or maybe the multiplexer. When we turn on the HID, the warm up period sucks a lot of juice... Maybe the car's harness is able to support this (like ORIENT EXPRESS said).... Maybe the multiplexer or an other part of the circuit has difficulties. I think that using the relay harness is a safer way. |
| Instalação de xenon no farol baixo | This thread | Refback | 09-14-2011 05:01 AM | |
| HID: How much on an 8th gen??? | This thread | Refback | 09-10-2011 03:07 AM | |
| 07' SI, HID install Q's... - HondaCivicForum.com | This thread | Refback | 09-02-2011 06:02 PM | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 100 | 11-11-2010 01:49 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
