#341 (permalink) | |
#342 (permalink) | |
2007 Taffeta White Civic Si Coupe |
#346 (permalink) |
Is the color shift really that drastic? I just want WHITE light WITHOUT even a tad of yellow in it. If they shift toward the blue side, would I want to get 5k? I've seen 6k kits in person and love it. How long does it take to color shift anyways? I'd hate to drop the dough if it's going to end up TOO blue.
#347 (permalink) | |
![]() Join Date: Sep 2006
I Love Kristina
these won't. |
#349 (permalink) |
okay i got these kits about a week ago, been lazy to install. finally took the time to install them today...okay first off, the price was good...shipping was excellent, but the installation process was NOT pleasant at all. it was quite hard to fit the bulbs into the hole perfectly, unlike the OEM bulbs (that pushes right in so you can twist to lock)...i had one bulb that would not go in no matter what, i had to sand down some stuff..to make it slide in...cause the sizin was just too diferent, it wa a lot thicker than the OEM ones, making them harder to push in...the right side struggled to get in..while the left one could not at all...it took hrs to finally get them to...go in...however the ballast was a piece of cake...i put it next to the bumper..inside the fender..(not touching any part of the car)...there was a hole that allows the 10mm screws to be screwed on perfectly...i think honda intended for the hole to be used that way...it went perfect...n theres a hole for both sides..so i had a perfectly installed ballast on both sides. there was no wires in the way or near it.. HOWEVER, there was one huge problem that bugged me. 2 nights ago when i tried to do this...i connected the ballast to the bulb...it DID NOT WORK...but i tried to use the relay wires, to connect to the battery...it worked! but however tonight, i plugged in the ballast and bulbs it worked perfect fine...so i was liek screw the relays...lol...i installed them...n it works great..i love the color, it looks awesome. anyways, i wanna know WHAT DOES THE RELAY WIRES DO EXACTLY?! i mean what exactly is better if i used it.
#350 (permalink) | |
#351 (permalink) | |
I Love Kristina
And one more thing I don't get, if these ballasts were tested by being submerged into a pool of water, then why do we need to worry about water when installing these Anywhere should be fine then.
#352 (permalink) | |
yes originally, i did put it like how the thread indicated..at first the right side, then when i was doing the left side, it was a lil bit complicated...because the screw i was suppose to use, was too short...i had to replace the oem ones with the ones that came in the kit, and i couldnt access the screws to unscrew it...only way i could do it is by removing battery and ecu out of the way. so i looked for another alternate. finally i found a hole that would be perfect for the ballast. and i went back to the right side n found that the exact same hole and position as the left side. and so i changed it for the right side, and everything was perfect...i loved the way the ballasts are harnessed right now...it is PERFECT. im gonna leave the relay wires alone n just leave it here, since its not that important. thanks a lot for the reply...im doing the fog lights soon. ill have some pics up for the HID soon...the quality is excellent!!! money well spent!! but the product coul've been manufactured better. |
#356 (permalink) |
guys i used and bought bulbs from the guy on ebay and one of my bulbs went bad (It turned pink) I informed him of the problem and he gladly sent me 2 more bulbs for free! No shipping or anything. All I have to say is that I am very satisfied with the ebay sellers customer service and will definatly buy from him again in the future.
#358 (permalink) | |
A couple of days ago both low-beam bulbs burned out at the same time while I was driving. No electrical problem caused this. The bulbs were the Sylvania Ultra and were about 10-months old, about the time for them to burn out based on other people that use them. I had to use the high beams to drive. It got me home, but made for some very unhappy on-coming traffic. |
#360 (permalink) | |
| 2006+ Honda Civic and Civic Si Performance Parts | This thread | Refback | 02-22-2008 01:30 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 02-18-2008 09:39 PM | |
| 2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs | This thread | Refback | 02-12-2008 02:44 AM | |
| DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum | This thread | Refback | 01-30-2008 03:43 PM | |
| HID Xenon Headlight Conversion Kits | CorSport | CorSport | 98 | 08-18-2009 03:41 PM |
| hid installation help. | StyleZ | California South | 14 | 10-22-2008 08:54 PM |
| Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand | coach2fast | Lighting, H.I.D.'s, & Neon | 9 | 12-06-2007 12:36 AM |
| Question about HID Installation | Tri3Dent | Lighting, H.I.D.'s, & Neon | 6 | 11-19-2006 05:06 AM |
| New Black EX SED. HID TIME.. or. do it right? | jehu4u | Lighting, H.I.D.'s, & Neon | 6 | 03-29-2006 01:14 AM |
