My Civics HID DIY Installation - Page 15 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 07-05-2007, 04:04 PM   #281 (permalink)
David
I tried to grind it down with a dremel but I can't see what part needs to be ground down. I tried grinding the base where the 3 little "ears" are and it didn't seem to help. I was afraid to grind off too much. I guess if it moves around or falls out I'll have to try to grind some more.
robinsonda1 is offline   Reply With Quote
Old 07-06-2007, 08:32 PM   #282 (permalink)
mochee_garage's Avatar
very good thread.
6K have the best light outputs!
mochee_garage is offline   Reply With Quote
Old 07-07-2007, 12:56 AM   #283 (permalink)
Orient Express's Avatar
A suggestion for the stuck bulb owners
May I suggest that you don't grind anything, just try a different way of seating the bulb.
If your bulb is getting hung up, it is usually in the last 5 degrees of rotation, and is being caused by the top bulb base ear pushing up against the the snap clip spring in the headlight housing. This clip is a little stiff and can make fully installing the bulb difficult.
To get around this and to get the bulb base to "click" in place, push on the bulb base with a flat-bladed jewelers screwdriver. Turn the bulb as much as you dare by hand and then use the screwdriver blade to push on the top ear that has to pass the snap clip. To make things easier, also lubricate the bulb base with some silicone lubricant. Use a Q-tip to apply the lubricant to the bulb base.
Orient Express is offline   Reply With Quote
Old 07-07-2007, 05:54 AM   #284 (permalink)
David
That sounds like it might work however, I can't push it in far enough for the ears to go in past the retaining ring. It seems to not want to go in all the way and I can't get enough pressure on it in that small space. I will try lubricating it and see how that works.
Old 07-07-2007, 10:22 AM   #285 (permalink)
David
OK I found some grease and lubed it up and it popped right in. Thanks for the help. I wonder why the left one was so hard, the right one went in without a problem.
Old 07-07-2007, 12:21 PM   #286 (permalink)
Great to hear.
I have always found that if the hole is wet and slippery, it makes it much easier to stick the shaft in.
Old 07-07-2007, 12:35 PM   #287 (permalink)
David
Originally Posted by Orient Express
Great to hear.
So true I should have tried the KY first!
Old 07-10-2007, 10:54 PM   #288 (permalink)
mikey
do u have to cut wires or is it cut plug adn play
crableg85 is offline   Reply With Quote
Old 07-11-2007, 12:07 AM   #289 (permalink)
stare_decisis's Avatar
Milad
looks like plug and play (Pnp) to me.
stare_decisis is offline   Reply With Quote
Old 07-11-2007, 01:17 AM   #290 (permalink)
No wires were cut or harmed in the installation of this HID kit.
Old 07-13-2007, 08:20 AM   #291 (permalink)
David
Agreed, totally plug and play. The hardest part is getting to the light which can be a real b!tch. Also people seem to have trouble getting the left light to go in for some reason but just lube it up and it will pop right in.
Old 07-13-2007, 06:54 PM   #292 (permalink)
Liu
Liu's Avatar
Just be sure to not get any lube on the bulb, in fact, don't even breathe on it.
Liu is offline   Reply With Quote
Old 07-14-2007, 07:47 PM   #293 (permalink)
Dave
yea i had that problem with driver's side lamp...coudln't push enuf to turn..
it's been 4 days now hoping for the best since i'm too lazy to take off the wheel and all that =_=
btw, when you face ur car to a wall, do you notice a little rainbow effect on a top cutoff area? it is a minor thing but kinda annoys me seeing it...
would there be a fix to that?
thank you in advance!
daveshin is offline   Reply With Quote
Old 07-15-2007, 12:42 AM   #294 (permalink)
HondaFREAK's Avatar
I think the housing on the driver side is narrower, because I had the same issue. But the rainbow affect you're talking about is the glare from the HIDs in the reflector housing. Whole reason that people get projectors is because of that chromatic rainbow. tends to through bright light up toward oncoming traffic
HondaFREAK is offline   Reply With Quote
Old 07-17-2007, 05:44 AM   #295 (permalink)
TafEx's Avatar
Here are some pictures from my install. It took me about 2.5 hours, but that's because it took me 45 minutes to figure out why it wasn't working. Turns out that I didn't connect one of the connectors securely enough. I think if you know what you're doing, and connect things properly the first time, it should take about 1 hour. Finding a place to mount the ballast on the passenger side was easy, as shown in the tutorial. For the driver's side, you have to be more creative. I found a place right in between the wheel well and the bumper. Oh, and mine are 6000k.
Before:
After:
Before:
After:
Before:
After:
And I found this little bugger when I was working on the right side.
TafEx is offline   Reply With Quote
Old 07-17-2007, 12:23 PM   #296 (permalink)
Very nice!
Old 07-18-2007, 06:06 PM   #297 (permalink)
I need help.
I just went and tried to test out my kit. I have the same kit from the same vendor. I connected all the wiring and double checked. I turned on my engine, and turned the switch but nothing happened. I tried a few more times but my lights wont turn on. Can you help me out. Is there something I'm missing? I have everything that Orient has.
Please help. Thanks in advance.
decemb3r is offline   Reply With Quote
Old 07-18-2007, 06:09 PM   #298 (permalink)
David
First thing I would recommend is that you make sure the connections are secure, use channel locks or something like that to clamp the connections tightly. I had the same problem at first, I thought it was tight enough but I was wrong. Once I squeezed it with channel locks the light came on. Try this 1st and then go from there.
Old 07-18-2007, 06:17 PM   #299 (permalink)
TafEx's Avatar
Originally Posted by decemb3r
I need help.
Same thing happened to me. robinsonda1 is correct. You just have to connect everything securely.
Old 07-19-2007, 09:09 PM   #300 (permalink)
Coastale's Avatar
I just did my install with the , 5000k. I'm very happy with the color. . . just a tick higher k than factory HID, I posted a video of it on youtube, but as you all know, HID in pictures is hard to capture. (Just search for Civic 5000k) The color is like pure white with the tiniest bit of blue/indigo/violet in it.
TafEx, I ran into a similar problem. Someone said channel locks and that worked for me perfectly. It's really hard to get enough leverage between your factory plug and the plug for the kit. 2 Channel locks, one on either side of the connection and you slowly snap it together. Reassuring *click*!
I also found a really good new place to mount the ballasts. It requires a torx T30 (Starbit) but you can bolt it on directly! I want to post picture of this and my lights. . . what is a good picture hosting service that people use on here?
Thanks, Coastale.
Coastale is offline   Reply With Quote
Instalação de xenon no farol baixo This thread Refback 09-14-2011 05:01 AM
HID: How much on an 8th gen??? This thread Refback 09-10-2011 03:07 AM
07' SI, HID install Q's... - HondaCivicForum.com This thread Refback 09-02-2011 06:02 PM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 01:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 09:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 03:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 100 11-11-2010 01:49 PM
hid installation help. StyleZ California South 14 10-22-2008 08:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 05:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 01:14 AM
