LinkBack (4) Thread Tools Display Modes
Old 05-18-2007, 04:03 PM   #221 (permalink)
Coastale's Avatar
Very nice, clean. What K is that? (Pics always come out bluer because of some kind of adjustment with digital cameras).
Coastale is offline   Reply With Quote
Old 05-18-2007, 06:22 PM   #222 (permalink)
2RotorMotor's Avatar
the flicker is normal, its just the bulb heating up.
2RotorMotor is offline   Reply With Quote
Old 05-21-2007, 02:11 PM   #223 (permalink)
Scrodums
Yodums's Avatar
The Stig
I hope you don't mind, but I decided to sticky this. Great guide. It should have been done a lot sooner. I refer back to this guide a lot and judging by the amount of replies this thread has gotten, it'll help other members as well.
Old 05-21-2007, 02:15 PM   #224 (permalink)
Orient Express's Avatar
Can you sticky and edited one that just has the guide in it and not all of the comments?
Orient Express is offline   Reply With Quote
Old 05-21-2007, 02:20 PM   #225 (permalink)
Scrodums
Yodums's Avatar
The Stig
Yes, I can. Just re-create the post, PM me the link and I'll stick and lock it.
Old 05-22-2007, 05:08 PM   #226 (permalink)
I have just purchased the 4300K HID kit for my 2007 Civic. I was back and forth between 4300K & 6000K but I ended up going with the 4300K for, well, no real reason. I have friends who have the 4300K, 6000K, and I think an 8000K(?) kit and I liked the look of it the best.
Pics/Updates to come when I receive and install them.
Link if interested: http://cgi.ebay.com/ebaymotors/ws/eB...m=130113438106
DJJeffMills is offline   Reply With Quote
Old 05-22-2007, 11:44 PM   #227 (permalink)
Coop's Avatar
Coop
i got mine this last weekend. i cannot wait to install. they are the ones that i get, not the ebay. i will post pics when i get them in. ooooo, like a kid with a new toy.
Nice DIY
Coop is offline   Reply With Quote
Old 05-23-2007, 04:44 PM   #228 (permalink)
asndragonboii's Avatar
he sells 5000k too
Old 05-23-2007, 04:53 PM   #229 (permalink)
McQuaide182's Avatar
Are those legit? I have an 07 Si Coupe and I dont know jack about lighting, wiring or anything along those lines. All I know is 4300k is the way to go.
McQuaide182 is offline   Reply With Quote
Old 05-24-2007, 01:58 PM   #230 (permalink)
it does not work for mine, hook it up like the guy who started this DIY, yes everything is correctly hook up like it suppose to, i even switch back and forth w/ the ballast to the same bulb to see if the prob cause by the ballast...nope, still doesnt work. What happened to the relay cable? how come noone uses it?
joenguyen is offline   Reply With Quote
Old 05-24-2007, 03:58 PM   #231 (permalink)
even try using the relay hardness, still no light.
Old 05-24-2007, 05:42 PM   #232 (permalink)
Liu
Liu's Avatar
Then, if your halogen bulbs still work, both of your ballasts are probably dead with no flicker on either of the hid bulbs.
Liu is offline   Reply With Quote
Old 05-24-2007, 05:47 PM   #233 (permalink)
yes, probably. i think im the only person with this prob
Old 05-24-2007, 10:42 PM   #234 (permalink)
Liu
Liu's Avatar
No, when I first got mine, one of my ballasts and one of my bulbs were dead, just sent them both back and got it replaced right away.
Old 05-24-2007, 10:48 PM   #235 (permalink)
striker_1818's Avatar
I Love Kristina
probably switched polarity as in the + and - are reversed
striker_1818 is offline   Reply With Quote
Old 05-25-2007, 05:27 AM   #236 (permalink)
WILL THE 50 Watt KIT PUT OUT MORE LIGHT AT 12 VOLTS than the 35 watt? WILL IT BE SIGNIFICANTLY HOTTER?
wassup61 is offline   Reply With Quote
Old 05-25-2007, 10:06 AM   #237 (permalink)
Stick with the 35 watt kit and you will be fine.
Old 05-26-2007, 12:13 PM   #238 (permalink)
Englishe30's Avatar
Mark
Great DIY....Thanks for the info leading me to buy the same kit....Install was a breeze and could not be happier, can't wait for the nighttime....+1 Rep
Englishe30 is offline   Reply With Quote
Old 05-29-2007, 07:15 PM   #239 (permalink)
f14fighter's Avatar
New trick to pulling off the wheel liner clips...use a cotterpin remover or a hook/pick set. Can buy these tools from Sears for like 5 bucks each. The center of the clip prys up just a bit loosening the base. If done at a nice slow and easy pace, you can feel when the tension has loosened and it is time to pry up on the base of the clip. Tips from MECP/EET mobile installer. Another freebie...Listen to OE and do your homework, there is no need to use the additional relay harness. What is the point of having multiple relays in a circuit designed for one? This can actually be harmful in the long run given the switching time for the relays while activating=more strain on the wiring.
f14fighter is offline   Reply With Quote
Old 05-29-2007, 07:19 PM   #240 (permalink)
Englishe30's Avatar
Mark
i just use a flat-head screwdriver, works nice..
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-22-2008 12:30 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 02-18-2008 08:39 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 01:44 AM
DIY superbrightleds.com festoon bulb fix - 8th Generation Honda Civic Forum This thread Refback 01-30-2008 02:43 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 97 03-16-2009 04:52 PM
hid installation help. StyleZ California South 14 10-22-2008 07:54 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-05-2007 11:36 PM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 04:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 12:14 AM
