Old 11-20-2006, 07:27 PM   #1 (permalink)
4dr foglights question
im planning on getting some foglights for my 4dr sedan ex.
this one...
http://cgi.ebay.com/ebaymotors/06-07...spagenameZWDVW
or
http://cgi.ebay.com/ebaymotors/06-07...5594QQtcZphoto
im leaning toward the first one because its a bit cheaper. What do you guys think?
also my sedan has a open slot in which i useally put coins inside. im pretty sure thats where the on/off switch goes, how do i remove that slot and install my on/off switch there.
1sole is offline
Old 11-20-2006, 07:48 PM   #2 (permalink)
n00b retro whore
ethlar's Avatar
The second ones though slightly more expensive but they are from K2Motor, which many people on here have purchased, and i intend to soon.
The coin holder pops out once you remove a screw from behind. A good set of directions to do that are the installation directions from College hills for the LED lighting kit:
http://www.collegehillshonda.com/ins...lumination.pdf
follow it up to about step 7 and that should help.
ethlar is offline
Old 11-20-2006, 08:31 PM   #3 (permalink)
o so basically i have to remove the whole dashboard to get the screw, unscrew right.
1sole is offline
Old 11-20-2006, 08:32 PM   #4 (permalink)
and is it require to drill any holes like the coupe?
1sole is offline
Old 11-20-2006, 08:41 PM   #5 (permalink)
n00b retro whore
ethlar's Avatar
its not as bad as it seems to get at the screw, just be careful, and actually use the towels like they say, it helps.
yes some drilling and cutting will be necessary but it should be similar to the OEM fog instalation
http://www.collegehillshonda.com/ins...oglightkit.pdf
ethlar is offline
Old 11-20-2006, 08:48 PM   #6 (permalink)
Garrison's Avatar
Garrison
http://www.madrt.com/images/clint/Civic/Fogs/Garrison/
Actually you will remove the lower panel, the upper panel from around the steering wheel. Be careful around the light lever. Then it is two screws that unscrew and an adapter will screw back in and the switch will pop in. Some info to have ready before you start is where the ground screw is under the dash to ground to. Then the fuse box where the adapter plugs into, and the the second cable unplugs to provide the power slot for the fogs. You will have to look up where, because I can't remember. PM DAKRAVEN, if you have questions he is the one who helped me do mine.
Garrison is offline
connecting foglights HeLLz aNgeL Inside and Out 2 10-16-2006 04:55 PM
foglights in winter HeLLz aNgeL Inside and Out 7 10-14-2006 07:20 PM
Question about foglights and installation... vincere Lighting, H.I.D.'s, & Neon 2 10-10-2006 12:30 AM
Quick Question... Ortiz83 Civic SI 5 06-14-2006 11:12 PM
question about integra in japan 2000civic Garage 10 06-10-2006 08:34 PM
