Arrgggh, have to redo my retrofit - 8th Generation Honda Civic Forum
Old 02-08-2010, 04:06 PM   #1 (permalink)
djpaw's Avatar
I did a projector retrofit DIY back in May 09......No issues, drove from Wisconsin to Jersey and loads of driving all over the east coast since then.......no problems.
Yesterday, out of no where.....the shroud on one head light comes apart within the housing.......can't believe JB weld could not hold that, maybe it became too cold for JB Weld. Gets very cold and windy where I live.
Or maybe its horrible Jersey Roads.
Anyhow, now I have to remove the headlights, bake em apart, redo the shroud.....and have to wait till its at least 50F to be able to touch the car.
Have to drive around with a loose shroud around till mid march I guess. FML
djpaw is offline
Old 02-08-2010, 06:22 PM   #2 (permalink)
BrooklynVtec's Avatar
Damn sorry to hear all that work and now more work ahead. sucks.
BrooklynVtec is offline   Reply With Quote
Old 02-08-2010, 06:26 PM   #3 (permalink)
JDMFGSI's Avatar
Tommy GuNZ
sucks for you...
JDMFGSI is offline   Reply With Quote
Old 02-08-2010, 06:45 PM   #4 (permalink)
StupidPig's Avatar
ahhh, sorry to hear that. Did you coarse sand the surface before you apply the JBWeld? That's should help.
StupidPig is online now   Reply With Quote
Old 02-08-2010, 08:33 PM   #5 (permalink)
djpaw's Avatar
yeah, i'll give the sanding a shot......it won't take more than a couple of hours...just have to wait for good weather now
djpaw is offline   Reply With Quote
Old 02-09-2010, 12:28 AM   #6 (permalink)
dang thats a bummer
hopefully the sanding will work better
jester0110 is offline   Reply With Quote
Old 02-09-2010, 06:17 AM   #7 (permalink)
iCeMaN57's Avatar
David
That's no good. Good luck!!
iCeMaN57 is offline   Reply With Quote
Old 02-09-2010, 03:14 PM   #8 (permalink)
devani's Avatar
good luck, the roads in NJ are the best in the country....but I would do it in the weekends, loose shroud is not good...use plenty of JB weld when you open it apart
devani is offline   Reply With Quote
Old 02-09-2010, 06:50 PM   #9 (permalink)
Brendan
Just curious, but why do you have to wait for good weather? Can't you just remove the headlight and fix it indoors? Sorry to hear you're having issues with the retro though. It's worth the hassle, I love my retro's
SloppyJoe is offline   Reply With Quote
Old 02-09-2010, 10:35 PM   #10 (permalink)
djpaw's Avatar
Actually they are pretty nice roads all over nj, just jersey city they suck.......
I need warm weather to take em off the car...its too cold to get that bumper out......I can clear headlights and put em back in 45 mins flat......
yeah, retros are so worth every penny and effort....more value for money than anything.
Old 02-12-2010, 02:04 AM   #11 (permalink)
You may want to look into a more flexible adhesive like Goop. I have used that stuff for everything. JB Weld like most epoxies have a strong hold but get extremely brittle in the cold. They do not tolerate shock and vibration well. For something like slipping a shroud over something, Goop may be the ticket. It is crystal clear, fills gaps wonderfully, and is extremely sticky. It cures into a strong, yet slightly flexible bond that resists cold, heat, and moisture. Look into it.
SparkyHT is offline   Reply With Quote
Old 02-14-2010, 02:47 PM   #12 (permalink)
but I thought goop is not rated for such high temps...I think up to 150F. Did u use quick jb weld or normal weld?
SiWizard is offline   Reply With Quote
Old 02-14-2010, 04:04 PM   #13 (permalink)
fg2mike08's Avatar
depends what a part of jersey you go to some of the roads are good some s*** i will warn you if you are driving up north stay of the kinnelon area are i work for the public works department and the roads are HORRIBLE, sorry to hear about the light tho man, hopefully we get some warm weather so you can fix it
fg2mike08 is offline   Reply With Quote
Old 02-14-2010, 04:07 PM   #14 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
Why do you have to wait until 50-degrees?
FijiBlueFG2HT is offline   Reply With Quote
Old 02-14-2010, 04:42 PM   #15 (permalink)
civic98turbo's Avatar
Nick
i'm guessing the sealant wont set in cold temps?
civic98turbo is offline   Reply With Quote
Old 02-14-2010, 06:32 PM   #16 (permalink)
Sucks to hear that, I am also in the process of redoing my retros bcuz my cutoff wasnt even. While im at it im going to go with the curve shield mod as well
You should look into High temp RTV silicone gasket maker, thats what i used and it was actually kind of hard to get the shroud off of the projector, just a though.
XkjeldorX is offline   Reply With Quote
Old 02-15-2010, 11:37 AM   #17 (permalink)
its_errick's Avatar
sucks
its_errick is offline   Reply With Quote
Retrofit Opinion(Other Retrofit owners please help!) BlackSi10 Lighting, H.I.D.'s, & Neon 31 05-03-2011 06:26 PM
My garage redo thecause17 Water Cooler 3 06-22-2008 09:17 PM
Retrofit Question tailam Lighting, H.I.D.'s, & Neon 2 02-19-2008 08:35 PM
Redo the seats nameless Inside and Out 9 02-15-2007 12:38 AM
Possible to redo tint? reaper702 Inside and Out 4 09-11-2006 12:16 PM
