Installed some HID headlights and now there is a problem - 8th Generation Honda Civic Forum
Old 02-04-2010, 12:09 AM   #1 (permalink)
Admin Ninja
obert's Avatar
obert
I installed some hids on a 07 si sedan. The first few times turning them on they came on the first time now you have to turn the light on and off 2-3 times to get the hids to come on ? Should I be worried or is this something that happens with some HID kits ?
They always come on and work fine after they come on so I d/k.
Thanks for all your help
My Civic Feature On NW-Built
obert is offline
Old 02-04-2010, 12:14 AM   #2 (permalink)
bujjg
things that might be wrong
1the power from the balist cable is not hooked up all the way but u cant tell cause it looks fine so u try to move it n see if ur light flicker if so its the balist number two its something to do with ur car wireing that it is not letting power threw 3 the connection between the balist n the car power is not connected right 4 the ground is not good 5 i cant think anymore
09dynodude is offline   Reply With Quote
Old 02-04-2010, 12:19 AM   #3 (permalink)
Admin Ninja
obert's Avatar
obert
Yeah I checked all the wires to make sure they were hooked up all the way. Should I not worry as long as they keep coming on ?
Old 02-04-2010, 12:53 AM   #4 (permalink)
CivicEX08's Avatar
Stephen
You probably have a faulty ballast(s). My fog lamps did the same thing and eventually only turned on when it felt like it. You should contact the company from whom you purchased them from and ask for a replacement. It will only become worse if you allow it to continue.
BTW: Do you have a 35 watt or 55 watt kit? You would need a relay harness for a 55 watt kit. The 35 watt kit doesn't require one but some recommend it. The 35 watt without a harness wouldn't be the problem but it may help others diagnose your issue and help if they have other ideas.
CivicEX08 is offline   Reply With Quote
Old 02-04-2010, 09:18 AM   #5 (permalink)
devani's Avatar
hooray for china kit...swap the ballast from left to right...recheck
devani is offline   Reply With Quote
Old 02-04-2010, 10:15 AM   #6 (permalink)
Admin Ninja
obert's Avatar
obert
Not sure what switching them would do sence they bolth come on at the same time.....there is a relay undere the dash that is part of the wire harness for the fog kit. Is that the relay you guys are talking about ?
THANKS FOR ALL THE HELP GUYS !!!!!!
best non-hid headlights babymobilsi Lighting, H.I.D.'s, & Neon 17 07-23-2009 11:31 AM
HID ILLUSIONZ Quad HID Setup Installed - Photos Vege-Taco Lighting, H.I.D.'s, & Neon 64 04-03-2009 04:49 PM
Does anyone have these headlights installed? nolan672 Lighting, H.I.D.'s, & Neon 1 12-11-2008 06:18 PM
problem with headlights stevediehlman Mechanical Problems & Technical Chat 3 03-27-2007 11:26 PM
