How to use Fog as DRL? - 8th Generation Honda Civic Forum
Old 09-13-2009, 10:58 PM   #1 (permalink)
fil3's Avatar
I have a problem. i want to switch my Fog light to be my day time running.
but the problem is the fog only ON when you switch headlight.
anyone know how to mod this?
fil3 is offline
Old 09-13-2009, 11:01 PM   #2 (permalink)
posterboy's Avatar
Bao Le
i hook up the fog with the parking light, and took off the fuse for drl.... i forgot which fuse tho, some1 in here can tell u that
posterboy is offline   Reply With Quote
Old 09-13-2009, 11:09 PM   #3 (permalink)
drivelikeyoustoleit's Avatar
Adam
fuse #37
drivelikeyoustoleit is offline   Reply With Quote
Old 09-13-2009, 11:10 PM   #4 (permalink)
posterboy's Avatar
Bao Le
and just turn on ur parking lights when u drive and boom !! ur fogs ir ur drl =]
Old 09-14-2009, 01:00 AM   #5 (permalink)
what if I wanted to run both my drls and my fogs at the same time.
hwlcd is offline   Reply With Quote
Old 09-14-2009, 04:32 PM   #6 (permalink)
Did you try switching the light stalk to the first position? When i do that my fogs turn on, its not oem harness though.
Bryan 07'CoupeEX is offline   Reply With Quote
Old 09-24-2009, 11:47 PM   #7 (permalink)
Denito914Fa5's Avatar
Denito
how bout on a si ? i dont think theres a parkin light..
Denito914Fa5 is offline   Reply With Quote
Old 09-25-2009, 12:04 AM   #8 (permalink)
Adam
^^^^^ search in the DYI section you'll find it and btw all civics have parking lights....
Old 09-25-2009, 12:51 AM   #9 (permalink)
Slowroll90's Avatar
Aaron
order the k2motor fog kit
use the wiring harness from k2 under the dash and leave the rest stock
that kit lets ur not only run ur fogs with the lights in the parking light position but also lets them stay on when ur high beams come on
Slowroll90 is offline   Reply With Quote
Old 09-25-2009, 12:56 AM   #10 (permalink)
Adam
just dont get caught running your fogs with high beams because most state laws maybe federal law says only 4 lights can be on the front of a motor vehical at one time
Old 09-25-2009, 05:41 AM   #11 (permalink)
wire up ur fogs 2 ur corners so they turn on the first click of the light switch
low&slow is offline   Reply With Quote
Old 09-25-2009, 05:54 AM   #12 (permalink)
fre$h si's Avatar
Bobby
did u have to splice for this?
fre$h si is online now   Reply With Quote
Old 09-25-2009, 07:56 AM   #13 (permalink)
DIY Oem Fog Lights with Parking Lights/ 06si
Originally Posted by webby
you're awesome - I'm about to probably call it a night as well.thanks for the help .
iluvmycsx is offline   Reply With Quote
Old 09-25-2009, 08:41 AM   #14 (permalink)
dcubed121's Avatar
David
Do you still want the switch to work?
are your fogs OEM?
the reason i ask is there are many ways this can be done.
dcubed121 is offline   Reply With Quote
Old 09-27-2009, 08:41 PM   #15 (permalink)
Slowroll90's Avatar
Aaron
yes good point, run all 6 at your own risk
Old 09-28-2009, 03:35 PM   #16 (permalink)
4EvAyOuNg's Avatar
I think he's trying to have his fog lights come on ONLY instead of the DRL. It seems like he wants them on WITHOUT having to turn on the parking lights.
4EvAyOuNg is offline   Reply With Quote
Old 09-28-2009, 03:40 PM   #17 (permalink)
4EvAyOuNg's Avatar
ANYTHING is possible with just rewiring! =P
Heres some pictures of my car and my lighting wired up to switches to run how ever you want it to.
FOG LIGHT ON ONLY
DRL ON ONLY
LEDs ON ONLY
Now with it all wired to switches you can change it up like this.
DRL AND FOG LIGHTS ONLY
DRL AND LEDs ONLY
FOG LIGHTS AND LEDs ONLY
LAST BUT NOT LEAST ALL THREE
Old 09-28-2009, 06:50 PM   #18 (permalink)
Adam
^^^^^ thats looks nice
Old 09-28-2009, 08:17 PM   #19 (permalink)
4EvAyOuNg's Avatar
Thumbs up
thanks
Old 10-01-2009, 04:41 PM   #20 (permalink)
fil3's Avatar
nice.. they look good.. i have all the same ligh as u have Fog LED DRL.. but my FOG and LED are wired together... and is OEM from ebay.. so the only part is how to link them up with DRL
fil3 is offline   Reply With Quote
DRL question Br3aker4lyfe Lighting, H.I.D.'s, & Neon 4 05-03-2009 04:15 AM
Drl KC2LLW Lighting, H.I.D.'s, & Neon 6 09-26-2008 02:40 PM
Drl GreyK20 Lighting, H.I.D.'s, & Neon 1 09-11-2007 05:17 AM
Hid DRL and Fog Question Otherguy Do It Yourself Articles 3 02-02-2006 12:42 PM
