Fog Light Stalk Swap - 8th Generation Honda Civic Forum
Old 09-11-2009, 05:34 PM   #1 (permalink)
wheeler's Avatar
Dave
Have OEM fogs with switch installed left of steering wheel. Anyone point me to a DIY swap out for the newer stalk? I see the full DIY installs, but anyway to just swap out the OEM switch for the stalk with minimal destruction?
wheeler is offline
Old 09-11-2009, 05:36 PM   #2 (permalink)
0720Steve's Avatar
3 screws underneath....stick your fingers in above the steering wheel in between the wheel and the top plate and pry the top lid up. turn the wheel to get access to the screws better. unclip the wires and it slides straight out to the left. when you put it back together, mind the tabs. it will lock back together correctly if you are nice to it.
0720Steve is online now   Reply With Quote
Old 09-11-2009, 05:38 PM   #3 (permalink)
wheeler's Avatar
Dave
so it's a direct swap out? I can integrate my OEM wiring to the new stalk?
wheeler is offline   Reply With Quote
Old 09-11-2009, 07:37 PM   #4 (permalink)
StupidPig's Avatar
Isn't the harness also different? I doubt you can just change the stalk and have it work.
StupidPig is offline   Reply With Quote
Old 09-11-2009, 07:40 PM   #5 (permalink)
wheeler's Avatar
Dave
That's what I'm wondering, what is involved with swapping it? If I have to rewire it all it's not worth it, but if I have to swap a harness and the switch then maybe.
Old 09-11-2009, 08:17 PM   #6 (permalink)
gmoneyhobbit's Avatar
Geoff Day
are you talking about removing the button on the dash and using the stalk instead?.
gmoneyhobbit is offline   Reply With Quote
Old 09-11-2009, 08:38 PM   #7 (permalink)
0720Steve's Avatar
i didn't realize what you were trying to accomplish. so you want to put the stalk on your 06-07? not sure about that one.
Old 09-11-2009, 09:40 PM   #8 (permalink)
Geoff Day
yeh im pretty sure those wires are absent from the harness plug on the stalk. you would have to wire those into the stock stalk harness for it to work
Old 09-11-2009, 10:37 PM   #9 (permalink)
joon joon's Avatar
u would need the interior harness and the stalk... im pretty sure thats all u need, but someone confirm this please..
joon joon is offline   Reply With Quote
Old 09-11-2009, 11:10 PM   #10 (permalink)
wheeler's Avatar
Dave
That's exactly what I wanted to do. Trying to figure out what all is needed for such a swap
OEM fog stalk code DamirG Lighting, H.I.D.'s, & Neon 5 05-14-2009 06:47 PM
Stock Fog Light blub swap? Airwolf Lighting, H.I.D.'s, & Neon 1 04-17-2006 03:00 PM
