Courtesy Light Install Help - 8th Generation Honda Civic Forum
Old 09-09-2009, 08:51 PM   #1 (permalink)
joey.walla's Avatar
Joey
Yesterday I began installing my Cold Cathode lights in my car.
I decided to hook them up here, as I saw in another DYI.
BIG PICTURE
Detailed Picture (tapped into pink and light blue on blue harness)
The lights however turned on when I unlocked, locked the car, and when I turned on the car. Whenever I put the car in motion though, the light turned off. (otherwise acting like dome light when on "door" notch)
So today, I decided I was going to rehook them up. I uninstalled everything and put everything back to stock. Unfortunately, my dome lights will not come on, front or rear. I checked the interior light fuses, good, checked the blue connector, good.
Idk what's going on.
CLIFFNOTES
Question 1) How do I get my lights working as stock?
Question 2) After 1 is solved, how do I have my courtesy lights stay on all the time?
(If you need more information/pictures, let me know)
Thanks,
Joey
joey.walla is offline
Old 09-09-2009, 09:02 PM   #2 (permalink)
joey.walla's Avatar
Joey
joey.walla is offline   Reply With Quote
Old 09-10-2009, 11:20 AM   #3 (permalink)
elementofhoops's Avatar
You checked the fuse under the hood?
elementofhoops is offline   Reply With Quote
Old 09-10-2009, 01:52 PM   #4 (permalink)
joey.walla's Avatar
Joey
On the interior fusebox I checked 14 (Small light interior) 19 (small lights main)
I did not check the underhood one, i'll go do that now.(I'm going to check 22 [interior lights]) Just so we're on the same page. lol
Thanks for the help btw.
Old 09-10-2009, 01:58 PM   #5 (permalink)
Thousand bucks says it's that one. Hahah. I blew that like 10 times.
Old 09-10-2009, 02:22 PM   #6 (permalink)
joey.walla's Avatar
Joey
Alright you win, give me your paypal account. lol
Ok next step, they don't stay on when I'm driving, only when I get in the car, out, etc.
This is where I already have two wires. Next step?
Old 09-10-2009, 03:10 PM   #7 (permalink)
joey.walla's Avatar
Joey
Old 09-10-2009, 05:01 PM   #8 (permalink)
joey.walla's Avatar
Joey
for
Old 09-10-2009, 05:44 PM   #9 (permalink)
hook up a 3 way switch, the common pin is the grounds from the leds, the left and right are either the constant ground (ground bolt), and the controlled ground (dome light ground).
Old 09-10-2009, 05:49 PM   #10 (permalink)
joey.walla's Avatar
Joey
I have to have a 3 way switch? Wouldn't the switch be needed to turn the power off not on?
Old 09-10-2009, 05:52 PM   #11 (permalink)
mikeubus's Avatar
Michael
you want to drive with the lights on all the time? kinda rice a rific if thats the case why did you tap in to something that only comes on sometimes.. instead of running it to a power source you can turn on and off on your own. like the parkin lights or to a switch of its own?
mikeubus is offline   Reply With Quote
Old 09-10-2009, 05:54 PM   #12 (permalink)
You sir, are mistaken. The dome light power is constant... its the dome light negative that is controlled.
Old 09-10-2009, 05:58 PM   #13 (permalink)
mikeubus's Avatar
Michael
im not mistaken, if he wanted to have the lights come on while he is driving why hook them up to something that you have to controll that should not be controlled? when you have something as easy as a parking light source or even better to just wire them up to a new acc fuse or source and then run a switch he can turn on and off..
Old 09-10-2009, 06:26 PM   #14 (permalink)
ahhh, ok. My bad. I'm sorry. Yes, I do agree with you. He has them wired incorrectly for his application.
Old 09-10-2009, 06:31 PM   #15 (permalink)
mikeubus's Avatar
Michael
there we go.. see i know i was on the right page there.... why would you want the lights on all the time?
Old 09-11-2009, 09:30 PM   #16 (permalink)
Jin
Hey guy.
I installed some Cold Cathode lights while back, so I know excalty what you are trying to do. for me, installed 3sets of differents cold cathode lights..
1 set of blue in front, 1 set of black light in front and 1 set of black light in the back seat. the 2 sets of blacks lights can be turned on ONLY if I turn on the headlight at night, and the blue light has three functions: 1) always on. 2)always off. and 3) works with the dorm light.
so for the blue light, whenever I unlock or open door, my blue cold cathode lights will light up. but I can turn the cathode light on even when the dorm light turns off. and finally i can turn it off so that it won't light up when the dorm lights are on.
if this is what you want to do I can help you do it. let me know.
p.s I didn't hook my lights into the harness. (theres easiler way to do it!)
*edit
My Cathode Courtesy Lights with Custom Switches!!
my lights
anchovyisjin is offline   Reply With Quote
Old 10-11-2009, 01:21 PM   #17 (permalink)
dcubed121's Avatar
David
Originally Posted by anchovyisjin View Post
Hey guy.
*edit
my lights
where did you hook them in?
dcubed121 is offline   Reply With Quote
hey courtesy light!! Bigjay1six1 Florida 3 10-23-2008 02:37 AM
Courtesy Light to Dome Light on Australian Civic archangel513 Do It Yourself Articles 0 04-27-2008 04:52 AM
if that is the courtesy light... then what is hc806 Civic SI 14 03-05-2008 12:37 AM
Courtesy Light Install J-Ro Lighting, H.I.D.'s, & Neon 48 06-17-2007 11:06 PM
courtesy light f*** up Secro Lighting, H.I.D.'s, & Neon 4 12-27-2006 04:24 AM
