Hid's wont turn on - 8th Generation Honda Civic Forum
Old 09-06-2009, 08:40 PM   #1 (permalink)
xmrfx's Avatar
Matt F
Hid's wont turn on
So the other day i went to turn my lights on all the did was turn on then instantly turn off...so i tried them again and the same thing happened but now they wont even turn on at all...I have the McCulloch hid kit with the wiring harness from retrofit source...i checked the fuse and its still good...anyone have an idea of why they wont turn on?
xmrfx is offline
Old 09-06-2009, 08:57 PM   #2 (permalink)
Wegue Wegue
Cr8tive_leo's Avatar
Adrian
Under warranty? Return them.
Using a relay? Do you hear your ballasts? Check your bulbs, are they 'burnt' ?
Last edited by Cr8tive_leo; 09-06-2009 at 09:25 PM. Reason: crap, I can't spell, this forum is gettign to me.. here.. hear.. hare...
Cr8tive_leo is online now   Reply With Quote
Old 09-06-2009, 09:19 PM   #3 (permalink)
xmrfx's Avatar
Matt F
well bulbs arent burnt just checked but now when the car is turning over they turn on but go right back out once the car is running
xmrfx is offline   Reply With Quote
Old 09-06-2009, 09:25 PM   #4 (permalink)
Wegue Wegue
Adrian
Are you using a relay?
Old 09-06-2009, 09:38 PM   #5 (permalink)
xmrfx's Avatar
Matt F
i think a relay was was with the harness
Old 09-06-2009, 09:45 PM   #6 (permalink)
miketat594's Avatar
check the relay, prolly went bad and you arnt getting the power to keep them on..you should hear the relay click..
miketat594 is offline   Reply With Quote
Old 09-06-2009, 09:50 PM   #7 (permalink)
xmrfx's Avatar
Matt F
ok i hear a click when i turn them off
Old 09-07-2009, 01:25 AM   #8 (permalink)
xmrfx's Avatar
Matt F
well i just disconnected everything then put it all back together and now the work...idk maybe i just had a loose connection
Old 09-09-2009, 12:06 AM   #9 (permalink)
fa5_4lyfe's Avatar
sal AKA-salamander
good job
fa5_4lyfe is offline   Reply With Quote
Old 09-09-2009, 08:03 PM   #10 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
that is the problem with only using one relay for both ballasts. Both your headlights go out if the relay goes out. That is exactly why our Xtreme kits come with a dual relay set up. Each side has it's own independent fuse/relay meaning that if a fuse/relay ever fails only one side gets effected.
Steve
www.KBcarstuff.com -HID Kits, Honda LED Bulbs,Civic LED Dome Lights, WeatherTech Liners and Mats
8thcivic.com SUPER SALE is on! - SAVE $$$
AUTHORIZED 8THCIVIC VENDOR SINCE 2005 - SHOP WITH CONFIDENCE!
XenonDepot is offline   Reply With Quote
Help with HID's Merlin21 Mechanical Problems & Technical Chat 6 07-11-2009 09:03 PM
HID's Anyone? Htuner34 Lighting, H.I.D.'s, & Neon 2 10-31-2008 05:20 AM
ghosts in the machine?? My turn signals randomly turn on... deltatechx Mechanical Problems & Technical Chat 20 10-03-2008 05:39 PM
Turn signals wont turn on! JDMjunKyFG Mechanical Problems & Technical Chat 1 08-17-2008 11:42 PM
PROBLEM: HID's won't turn off 3xodus Lighting, H.I.D.'s, & Neon 12 06-18-2008 05:20 AM
