Passenger DRL/Highbeam flicker - 8th Generation Honda Civic Forum
Old 09-05-2009, 04:23 PM   #1 (permalink)
Maybe you guys can help....
The passenger side DRL/Highbeam occasionally goes out while I'm driving or hit a bump. I looked at the bulb and switched it out with the driver side bulb that I know works and still the same things happens. Also, I'm thinking its the wire connected to the bulb itself cause when I move it the DRL/Highbeam flickers or sometimes stays on; at least until I hit a bump or something like that. Is there anyway to replace that wire??
Thanks!
Chris7686 is offline
Old 09-05-2009, 10:20 PM   #2 (permalink)
drivelikeyoustoleit's Avatar
Adam
aftermarket bulbs or stock?
drivelikeyoustoleit is offline   Reply With Quote
Old 09-06-2009, 11:15 PM   #3 (permalink)
They are Silver Star Ultras. Stock harness.
Chris7686 is offline   Reply With Quote
Old 09-07-2009, 12:48 AM   #4 (permalink)
Adam
how long have you been running the bulbs?
Old 09-07-2009, 01:46 AM   #5 (permalink)
av911's Avatar
Check your connections. Try your old bulbs and see if it still happens.
Old 09-07-2009, 02:39 AM   #6 (permalink)
9 months to a year... I think
Old 09-07-2009, 02:39 AM   #7 (permalink)
Tried that
Old 09-07-2009, 02:44 AM   #8 (permalink)
Adam
the bulb prob. just went bad i had the ultras as well only lasted a year i believe on the box is say expected life 12 months.... if it's not that then make sure you didn't fry any part of your harness the ultras run hotter then stock
Old 09-07-2009, 02:46 AM   #9 (permalink)
Adam
when i had mine the bulb looks like melted and warped the glass right before it blew i had one low beam go out then one high beam went out--- i don't think i'll ever buy ultras again i drive a lot at night and expect more then a year outta the bulbs
Old 09-07-2009, 04:22 PM   #10 (permalink)
But the bulb only flickers when I move the harness its connected to. So that's why I think its the harness. Do you know if the harness itself can be replaced?
Old 09-07-2009, 07:23 PM   #11 (permalink)
Adam
yea you can replace your entire headlight harness.... it'd cost a arm,leg,and nose from the dealer though... g/l
Headlight Flicker vipertag313 Mechanical Problems & Technical Chat 9 01-21-2009 02:18 AM
Yellow DRL/highbeam manchesfer Lighting, H.I.D.'s, & Neon 9 12-16-2008 11:45 PM
Highbeam question.... eXe Lighting, H.I.D.'s, & Neon 1 05-14-2008 09:20 PM
HID Flicker then...NOTHING calircr Lighting, H.I.D.'s, & Neon 13 03-04-2008 03:33 PM
HID still flicker? indoxbo1 Lighting, H.I.D.'s, & Neon 8 03-20-2007 11:15 AM
