k2motor fogs help! - 8th Generation Honda Civic Forum
Old 09-04-2009, 01:47 AM   #1 (permalink)
Sean
Exclamation k2motor fogs help!
So i got the k2motor fogs for the coupe but im having problems and they didnt even give me any instructions... ANYWAYS.. the problem is i dont know where the rest of the wiring goes. ive seen the DIY fogs installation and it looks nothing like it. maybe i have k2motors newest one so things are diff.
So heres the right side
and heres the left side
And the rest of the cables
Can anyone figure out the problem?!!! Please help out! Thanks!!!
civicbeast is offline
Old 09-04-2009, 02:37 PM   #2 (permalink)
Sean
bump... no one?
civicbeast is offline   Reply With Quote
Old 09-04-2009, 03:03 PM   #3 (permalink)
HTX
HTX's Avatar
how many harnesses total did u get? are u sure those are k2's? where did u get them?
HTX is offline   Reply With Quote
Old 09-04-2009, 03:13 PM   #4 (permalink)
sdej1's Avatar
Chris.
man i had the same problem wid my ej...
theyre still not on =[
so im sending it to my boy
so he can make me some new custom harness for it
or summin like that
sdej1 is offline   Reply With Quote
Old 09-04-2009, 03:14 PM   #5 (permalink)
f2kboost's Avatar
Farooq
u should have gotten another harness with the kit...i had the same exact wiring that u have but also got a another harness that relates to DIY that was posted..call the company up that u bought it from and see if they send u the other harness
f2kboost is offline   Reply With Quote
Old 09-04-2009, 03:41 PM   #6 (permalink)
HTX
HTX's Avatar
yeah mine came with 2 harneses i believe. The one that connects to the fogs is supposed to hook up to an oem harness by the windshield fluid tank and the other harness goes inside under the dash..
Old 09-04-2009, 03:50 PM   #7 (permalink)
f2kboost's Avatar
Farooq
Old 09-04-2009, 04:29 PM   #8 (permalink)
Poweraide's Avatar
Thats the older harness. I cant beleive they are still selling that. Most are like the OEM ones.
Poweraide is offline   Reply With Quote
Old 09-04-2009, 09:07 PM   #9 (permalink)
p1904's Avatar
Micho Rizo
DIY: Sedan Ebay (K2) Foglight Install With Pics
p1904 is offline   Reply With Quote
Old 09-05-2009, 05:58 AM   #10 (permalink)
I have the EXACT same problem and am really annoyed. It's totally missing a harness. Totally frustrated. I bought mine through newegg mall. I'm going to have to call them for a refund, and if that doesn't work dispute with my CC company. It's advertised as plug and play and is definitley not.
pblogic is offline   Reply With Quote
Old 09-05-2009, 02:07 PM   #11 (permalink)
Originally Posted by p1904 View Post
^^ This. Its not a difficult install just not oem and you'll need to buy a pin connector to get it to work.
Bryan 07'CoupeEX is offline   Reply With Quote
Old 09-05-2009, 02:22 PM   #12 (permalink)
yeah, like the pictures up top, mine wiring is not at all similar to the guide. It's not just missing a pin connector, it's missing anything you could connect the pin connector too. The only thing coming from the fog harness is the black connector with the fuse and the relay. That's it.
Old 09-05-2009, 02:39 PM   #13 (permalink)
ahhhh I gotcha thanks. Wow is that annoying. I appreciate your reply. They still sold me the wrong product which is very annoying. If they don't send me a new harness right away on monday I'm still going to dispute with my CC and put in a BBB complaint. It was definitley a sales misrepresentation.
Old 09-05-2009, 02:52 PM   #14 (permalink)
maximo61170's Avatar
gino
yea i got mine from newegg mall too.
Fog Wiring Problem. =/ With pix! =)
those are the wires it came with. i eventually just bought new wires from here. a lot of people have extras because they buy a new set to replace the fog and dont need the wires. yea it was a p.i.t.a. but whatever. fog are on new and i'm happy. =)
maximo61170 is offline   Reply With Quote
Old 09-05-2009, 04:56 PM   #15 (permalink)
Its the same harness i received and that you have, the diy is on that link just on page 16 in the middle. Here is what you're looking for:
http://www.8thcivic.com/forums/4986643-post314.html
Old 09-05-2009, 09:20 PM   #16 (permalink)
Sean
so basically its missing a set of wires?
Old 09-05-2009, 09:27 PM   #17 (permalink)
Sean
EDIT: I also forgot to add that theres another set of wires that go under the dash that is connected with the button to turn on the fogs. I HAVE THAT. Now, the last problem is i connected it with the other set of wires and grounded it, but the fogs wont turn on..
Old 09-05-2009, 09:46 PM   #18 (permalink)
Do you have the pin connector that goes into the interior fuse box? The pin connector will replace the i think brown connector (which ever color that isnt used for the actual switch). Did you run the single red wire through the grommet in the firewall to connect the interior and exterior harness?
Old 09-05-2009, 09:48 PM   #19 (permalink)
Sean
UPDATE! So heres my progress. Sorry for the bad pics...
Heres the red cable.
Heres the black cable.
Heres the relay and the fuse.
Heres where the other red wire connects to the other set of wires under the dash.
And heres the foglight button.
So my fogs wont turn on because im guessing im missing something or im grounding the black and white wire somewhere wrong under the dash. anyone know the solution?
Old 09-05-2009, 09:52 PM   #20 (permalink)
How are you connected into the interior fuse box?
k2motor fogs?? Bman825 Lighting, H.I.D.'s, & Neon 12 08-10-2009 10:21 PM
K2Motor Fogs, my second set arrived, and big surprise!! SilverBlue Lighting, H.I.D.'s, & Neon 0 04-23-2008 01:32 PM
Dash indicator to turn on with K2motor fogs? jasongg06 Lighting, H.I.D.'s, & Neon 1 01-26-2007 11:37 PM
k2motor Fogs (07) SacrificeTheory Lighting, H.I.D.'s, & Neon 0 01-02-2007 06:03 PM
