Aiming low beams help!!!
Ok so my low beam on the drivers side is really high.
I tried lowering the aim which i did and now the bulb is touching the bottom of the reflector and it's still high!!! What's the problem? Should I just take it to the honda dealer? Thanks |
David
the adjustment moves the entire reflector. if you moved your bulb you did it wrong. i would say check to insure your bulb is in all the way. did you recently go after market on the bulb? |
Adjustment is easy.
1. Look for the adjustment screw (passenger side shown) ![]() 2. Use a long philips screwdriver to turn it ![]() 3. Follow the directions inscribed on the plastic shroud, directly above the headlamps
it's not touching the reflector.. i just thought it was.. it's all good now.. and there's only one way to adjust the bulbs and that's by using the screwdriver to twist that bolt
#9 (permalink) | |
basically, how many turns to lower aim by an inch? My low beams are practically aligned with my high beams and people flash me all the time cause I'm blinding them. Thanks for the pictures! |
| DRL's Plus Low beams | ozstriker | California South | 9 | 05-31-2009 04:47 PM |
| High Beams ON, Low Beams OFF | mnrivera210 | Lighting, H.I.D.'s, & Neon | 5 | 03-24-2009 04:37 PM |
| low beams stay on when i go to high beams | T-Mac | Mechanical Problems & Technical Chat | 39 | 10-15-2008 01:18 AM |
| how to keep DRL's on with LOW BEAMS? | 4play4dr | Lighting, H.I.D.'s, & Neon | 1 | 09-15-2007 07:35 PM |
| keep DRL's on with low beams?? | EntropyXIII | Lighting, H.I.D.'s, & Neon | 10 | 07-20-2007 02:28 PM |
