Angel Eyes Wiring - 8th Generation Honda Civic Forum
Old 08-27-2009, 12:50 AM   #1 (permalink)
JohnnySak69's Avatar
Angel Eyes Wiring
Okay how do i wire angel eyes if i'm creating my own custom ones?
YouTube - Angel Eye self custruction
Using these angel eyes that is in the DIY how do i wire them to my car to be on when my key is turned to acc or something?
JohnnySak69 is offline
Old 08-27-2009, 05:14 AM   #2 (permalink)
Oh come on anyone?
I just need to find a way to get 12v :P
JohnnySak69 is offline   Reply With Quote
Old 08-27-2009, 05:41 AM   #3 (permalink)
dcubed121's Avatar
David
accesory wiring is 12V. you could tap the DRLs. if you want them on all the time i suggest taping one of the accesory wires.
dcubed121 is offline   Reply With Quote
Old 08-27-2009, 12:22 PM   #4 (permalink)
StupidPig's Avatar
I made a circuit to turn on a relay when either the Park light is on or DRL is running. The tricky part here is DRL is actually High Beam in about 60% PWM duty cycle, which you can just tap to the high beam and use that to power you LED (for some LED you still can, but it will be dimmer). If you just want you angel eyes light up when park is on, then you just simple tap it from the Park light wire.
And yes, tap to accessory is ok too, but you will need to route the wire through the firewall I guess, which I didn't try.
StupidPig is offline   Reply With Quote
Old 08-27-2009, 08:19 PM   #5 (permalink)
SO accessory wire is inside the cabin?
And where can this accessory wire be found?
But ya DRLs dont run fully so I don't want dim angel eyes, plus when i turn on my headlights the DRLs turn off and so will my angel eyes.
Old 08-27-2009, 09:04 PM   #6 (permalink)
StupidPig's Avatar
Well, with both DRL and Park as trigger signal, it's pretty much able to turn on the angel eye most of the time, the only time it is off (except the car is not started ) will be when you just started you car and never released the hand brake.
I'm unable to found any place to tap the accessory inside the engine bay, but I didn't search hard so may be you can found it. To get it inside the cabin, I think the accessory socket or the related fuse is the most obvious place.
Old 08-30-2009, 04:45 PM   #7 (permalink)
Ya there is a small firewall that I could go through to get into the main cabin for an accessory wire.
But tapping into DRLs would not give me the actual 12 volts that I need? Since DRL run off a lower amount of volts? Does anyone know what volts specifically?
And how do i actually connect it to the fuse? Do i wrap the wire around the fuse? Solder? Wire tap?
Old 08-30-2009, 11:59 PM   #8 (permalink)
StupidPig's Avatar
The DRL is the same 12V as Hi Beam, but in about 60% PWM duty cycle, which is equal to about 7.6V.
Old 08-31-2009, 07:15 AM   #9 (permalink)
jbsali's Avatar
Joel
im not really one for angel eyes as they are usually considered rice but... i do have to admit that is a pretty good DIY.
jbsali is offline   Reply With Quote
Old 08-31-2009, 04:04 PM   #10 (permalink)
Well since LEDs only really require 3.0-3.2v, the 7.6V should be sufficient enough to be lighting it at a normal rate as if it was 12v right? I just have to use a lower resistor?
Old 08-31-2009, 05:26 PM   #11 (permalink)
StupidPig's Avatar
As i said, the DRL is actually 12V, but it is using PWM running at about 60% duty cycle. 12V at 60% duty cycle is a square wave with 12V at 60% of the time, and 0V at 40% of time. So, you still need to have your LED able to run at 12V. It is different from a real DC 7.6v supply.
Old 08-31-2009, 05:46 PM   #12 (permalink)
So then if I want to connect it to the DRL how do i connect them? Wire tap the high beam wires?
And how do i get the angel eyes to be on at night when my headlights are on?
Old 08-31-2009, 06:22 PM   #13 (permalink)
StupidPig's Avatar
If you can go throught the firewall, I bet tapping to the accessory is the simplest way for you.
For me, I have special needs which anyway I planned to use a realy harness to power the angel eyes directly from battery, so that I tap to both the Park signal and High beam (with a capacitor to smooth the off cycle during DRL) to trigger the relay.
Wiring for Angel Eyes JohnnySak69 Lighting, H.I.D.'s, & Neon 20 04-08-2011 11:57 AM
Angel eyes? leCouturier Inside and Out 11 12-09-2008 12:17 AM
Angel Eyes Johannes Do It Yourself Articles 7 01-16-2008 09:53 PM
Angel Eyes zdragonsoul Lighting, H.I.D.'s, & Neon 30 12-01-2007 12:18 AM
Angel Eyes? Sunny Lighting, H.I.D.'s, & Neon 67 03-23-2007 06:26 PM
