Tito
are these legit?
LED 9005 18 SMDs Xenon HID White HeadLight Light Bulbs DRL's/High Beam
Tito
i seen someone selling them in the for sale section and they got them off of Ebay. I'm not sure what HiD's to get for my low beams and if i should change the DRL's and High beams. What do you suggest?
R18 crew member #193
try them out they look really good,
^^^ check out the before and after pics.. |
Boss- Ross
Yeah and then the next thing you know is that you'll need New Wiring for your stock bulbs and also maybe new Fuses...
I know LED are suppose to run cooler and more light. But I won't test this on my car... maybe an Older honda or Acura!
There are a lot of different LEDs available. LEDs that have high output also make a decent amount of heat. Obviously not as much heat as a halogen bulb. The problem is that LEDs dim if they over heat. This arrangement provides very little means for dispersing heat. There is no heat sink. candlepowerforums.com discusses this in detail. Thus I assume the output is lacking.
Edit: If I had bi-xenon retros, I'd want these to spruce up the stock off-white DRLs. Last edited by Keith P; 08-22-2009 at 10:31 AM. |
#10 (permalink) |
Carlos
You can't use them to drive with.. they are only for making it look like you have white lights in your DRLS/highbeams or foglights.. they workgreat for running with your high beams on all the time.. they're bright but no where near enough to drive with. They don't get hot by the way, they don't heat up at all...
| amazon.com legit? | k-fan | Bolt-Ons And All-Motor | 6 | 08-08-2009 11:12 AM |
| Do these HIDs look legit? | TheProdigy351 | Lighting, H.I.D.'s, & Neon | 8 | 06-25-2009 05:34 PM |
| cant tell if this site is legit. | joefg561 | Lighting, H.I.D.'s, & Neon | 8 | 04-26-2009 12:54 PM |
| is this legit? | nvmyrd4 | Car Builds | 9 | 02-20-2009 09:05 PM |
| Is this legit?! | daryll130 | Dealership Experience | 25 | 04-28-2008 10:58 AM |
