Fogs with CAI on 07 coupe - 8th Generation Honda Civic Forum
Old 06-21-2009, 03:56 PM   #1 (permalink)
Steve-0-32's Avatar
Steve
not sure if this question was asked or resolved, but i just installed my CAI and comming to notice that my fogs wont fit with the CAI right there behind the bumper, the fog light is too deep with the cai there. any resolutions? or ideas? any help would be greatly appreciated thanks.
Steve-0-32 is offline
Old 06-21-2009, 03:58 PM   #2 (permalink)
Will06SI's Avatar
Function over Form..
adjust the piping leading to the intake manifold until you have slightly more clearance basically every 1 has had this issue it will be a snug fit but you will get it too work..
Will06SI is offline   Reply With Quote
Old 06-21-2009, 04:06 PM   #3 (permalink)
Steve-0-32's Avatar
Steve
will try thanks
Steve-0-32 is offline   Reply With Quote
Old 06-21-2009, 05:28 PM   #4 (permalink)
ryryninja's Avatar
Ry [ the original mahfawker ]
You should be able to fit it because I use to have retro fogs with a CAI. The end of the housing would almost touch the filter on my setup.
ryry's part out thread
Originally Posted by InfamousN View Post
Man.. if I put something into my mouth and I think "Mmmm, RyRy bawlz".. We have problems.
ryryninja is offline   Reply With Quote
Old 06-22-2009, 04:00 AM   #5 (permalink)
pprancer's Avatar
James Cho
hmm weird... i have injen cai and retro fit fogs.. it did not fit at all. if it is regular fogs, it will fit fosure...
i even had to delete the resonator from oem intake to fit the retro fogs..
pprancer is offline   Reply With Quote
Old 06-22-2009, 05:50 PM   #6 (permalink)
my08Si's Avatar
Cliff
you can just push the filter onto the pipe more...thats what i did.
my08Si is offline   Reply With Quote
Old 06-23-2009, 02:40 AM   #7 (permalink)
pprancer's Avatar
James Cho
uhmm i heard thats not good for your engine..
Huston we have a problem..
Old 06-23-2009, 03:46 PM   #8 (permalink)
my08Si's Avatar
Cliff
well i didn't push the filter on to where you did in touching the tip of the filter. I jsut put it on a tiny bit farther tahn usual. so far no pblms here *knock on wood*
ebay Fogs for 07+ coupe si igotmysi Lighting, H.I.D.'s, & Neon 10 01-29-2008 04:20 PM
oem fogs on 07 Si Coupe koolgreen.com California South 12 09-29-2007 08:28 PM
07 si fogs did not fit in 07 coupe batxbat Lighting, H.I.D.'s, & Neon 4 03-10-2007 02:00 PM
07 Si coupe:OEM fogs or K2 xmx250 Lighting, H.I.D.'s, & Neon 3 02-02-2007 08:57 PM
