HID Probs - 8th Generation Honda Civic Forum
Old 06-13-2009, 02:02 AM   #1 (permalink)
HID Probs
I got an HID kit (full) 9006..bulbs and ballast. Taken off an 95 accord sedan. I tried wiring up the kit on my civic 07 sedan. And no lights.. Anyone have ideas? I asked a friend of mines that also owns the same car he wasn't to sure about it either..but he did say it might have something to do with the ballast's power or something. Ideas?
Hyptonix is offline
Old 06-13-2009, 06:18 PM   #2 (permalink)
db8typer's Avatar
Is this kit PNP?
db8typer is offline   Reply With Quote
Old 06-14-2009, 09:11 AM   #3 (permalink)
trehouse's Avatar
I'd say polarity or connectors not fully seated. I gather you know that the kit worked and that you tried both ballasts, etc.
As db8typer asked, the connectors match up with your civic don't they? Also, purple and other colors (I think I've also seen blue or green) in our civics are the +12 voltage.
trehouse is offline   Reply With Quote
Old 06-14-2009, 09:19 AM   #4 (permalink)
wlam85's Avatar
William
make sure all the connectors are plugged in properly. something you got to play with the wires for a little bit before they fully work.
wlam85 is offline   Reply With Quote
Old 06-15-2009, 12:52 AM   #5 (permalink)
Yeah the kit is PNP all match up and fit perfectly. But doesn't seem to light up at all. I'm 100% sure that the kit works.
Hyptonix is offline   Reply With Quote
Old 06-15-2009, 09:00 AM   #6 (permalink)
wlam85's Avatar
William
sometimes the wires arent truly connected even ho it may seem that they are
Old 06-15-2009, 09:08 AM   #7 (permalink)
Polarity..
Remove the pins from the connector and swap them (as in, remove the left pin and put it in the right pin slot, etc)
Faulty Ballast, unless it was completely dead, would at least attempt to fire.. even if it flickered..
Grommish is offline   Reply With Quote
Old 06-21-2009, 03:33 AM   #8 (permalink)
Yeah had no flickers no anything. Just straight up no lights no noise :S
Old 06-21-2009, 08:12 AM   #9 (permalink)
trehouse's Avatar
These are pretty old ballasts. If the ballasts are good they don't appear to be getting power (or enough power). As everyone is mentioning it could be polarity of the voltage to the ballast or the connectors aren't seated.
Look at your ballast and it may show which side of the connection is positive and try to confirm that your connector is wired the same. Purple, blue (I think), red all could be positive on your civic. Maybe even green. Black is typically your negative connection.
If you are entirely stumped some closeup photos of your install may help showing connections or at least make the thread a bit more interesting.
Old 06-21-2009, 04:29 PM   #10 (permalink)
try a relay....so do they even come on at all??
Krissy Baby is offline   Reply With Quote
fit and clutch probs? civicconvert06 Mid-Atlantic 2 01-02-2009 01:34 AM
Any probs with the r18 turbo? Honda9444 Turbocharging 17 10-17-2008 06:48 PM
subwoofer probs xSaoxOathx Mechanical Problems & Technical Chat 6 12-20-2007 10:00 PM
trunk probs DailyDrifted Mechanical Problems & Technical Chat 3 10-09-2006 01:21 AM
UK Civic probs notsofatso Mechanical Problems & Technical Chat 0 03-26-2006 01:41 PM
