Caution for HID users... - 8th Generation Honda Civic Forum
Old 05-20-2009, 10:10 PM   #1 (permalink)
Visionikz's Avatar
JD
I discovered today when testing the accord horn upgrade from College Hills that when you push and hold the panic button, the low beams flash along with the sidemarkers and taillights and horn of course. When I noticed while standing in front of the car that my HIDs were igniting and then turing off about every one second I was like ohh sh*t! As y'all know or SHOULD KNOW, turning HIDs on and off rapidly is very harsh on them. So if you guys(who don't have aftermarket alarms) can't find your car in a parking lot, think twice before using the panic button lol
Visionikz is offline
Old 05-20-2009, 10:15 PM   #2 (permalink)
FG1JDM's Avatar
David
Yeah I noticed the same thing. I have a backup set ay home
FG1JDM is offline   Reply With Quote
Old 05-20-2009, 10:16 PM   #3 (permalink)
CraZy LeGs's Avatar
thnx for enlightening me
CraZy LeGs is offline   Reply With Quote
Old 05-20-2009, 10:18 PM   #4 (permalink)
Josh
i figured about so when I put mine on, but this is a good reminder to all who have or thinking of upgrading.
DevilDoc87 is offline   Reply With Quote
Old 05-20-2009, 10:20 PM   #5 (permalink)
Admin Ninja
obert's Avatar
obert
Did not know that,thanks for the info !!!!!
Old 05-20-2009, 10:21 PM   #6 (permalink)
kicker18's Avatar
Sean
Some good info.
kicker18 is offline   Reply With Quote
Old 05-20-2009, 10:24 PM   #7 (permalink)
VanSi07's Avatar
I've never used the panic button, good to know I never will now!
VanSi07 is offline   Reply With Quote
Old 05-20-2009, 10:27 PM   #8 (permalink)
f2kboost's Avatar
Farooq
yea found out bout this 3 weeks ago when i was tryin to scare someone off my car using the panic button
f2kboost is offline   Reply With Quote
Old 05-20-2009, 10:53 PM   #9 (permalink)
p1904's Avatar
Micho Rizo
p1904 is offline   Reply With Quote
Old 05-20-2009, 10:58 PM   #10 (permalink)
Aaron
oh.......so i guess high beaming someone rapidly does the same effect too......?
sl33per is offline   Reply With Quote
Old 05-20-2009, 11:34 PM   #11 (permalink)
mrhappypantz's Avatar
Jason
^^ high beam and low beam aren't the same bulbs.
mrhappypantz is offline   Reply With Quote
Old 05-21-2009, 02:38 AM   #12 (permalink)
av911's Avatar
That doesn't mean they don't work together...
Delay On/Off HID Relay Harness
Old 05-21-2009, 10:04 AM   #13 (permalink)
djpaw's Avatar
Nice catch !!!!
djpaw is offline   Reply With Quote
Old 05-21-2009, 10:24 AM   #14 (permalink)
MRoCK's Avatar
mike saldaña
thanks for the info!!! does it mess up the bulb, the ballast or both???
MRoCK is offline   Reply With Quote
Old 05-21-2009, 11:21 AM   #15 (permalink)
SiConvert887's Avatar
Zach
True, but thankfully the only time they work together is when you use your high beams with your lowbeams off... it will turn your lowbeams on. So for those with HID low beams, always make sure your HID lows are on before flashing your high beams,
SiConvert887 is offline   Reply With Quote
Old 05-21-2009, 03:02 PM   #16 (permalink)
StupidPig's Avatar
^^^ Yes, basically the only situation get into problem is flashing someone in day time, unless you are the guy who keep your lower beam on day and night. And thanks OP for the tips on panic button, didn't know that will flashing your low beam too. Just another reason for using the relay harness I made.
Oh how about fog? will fog light flash with the panic button too?
StupidPig is offline   Reply With Quote
Old 05-21-2009, 03:23 PM   #17 (permalink)
chrisng's Avatar
Christopher Ng
Great info! i noticed that the lights did that too, and i thought cool! but i was unaware that it was bad for the lights, what is the reason for this?
chrisng is offline   Reply With Quote
Old 05-21-2009, 03:25 PM   #18 (permalink)
Eric
Is there a way to change the wiring so that the alarm links to the high beam bulb instead? Or is this hard coded into the ECU?
void is offline   Reply With Quote
Old 05-21-2009, 03:31 PM   #19 (permalink)
Sle
Sle's Avatar
Sam
^ yep mine does
Sle is offline   Reply With Quote
Old 05-21-2009, 04:09 PM   #20 (permalink)
Gecko5's Avatar
Thanks for the reminder about the low beams flashing with the panic button.
Gecko5 is offline   Reply With Quote
Caution: 2008 TW inside MOAR NEW PICS!! NO 56K JEA86 Introduction & Pictures 21 03-23-2009 08:28 AM
Water pattern of Windshield Wipers **Caution Noob Question** vipertag313 Mechanical Problems & Technical Chat 11 12-20-2008 12:29 PM
Few New Pics, (Caution, BIG pictures) audiophile Introduction & Pictures 8 03-08-2008 09:38 PM
aftermarket springs and adjustable coilovers Pay attention to the caution on the box eh_civicracer Suspension and Brakes 3 08-13-2007 06:53 AM
