No matter how hard i turn, there is no use getting out this burned out bulb out of my headlamp. Its the passenger side. The driver side took me less than 5 minutes. Any hints on what i should do? I cannot even get the clip off the bulb.
~(Ïn YØ fÅŒ)~
Popin Switches n Hitin Bitches
what i would do is use this
DIY HID/Bulb replacement DIY and have a better look at what might be causing the bulb to be stuck. If you are just changing the bulb from the front it might be hard to tell what its getting stuck on. You might need to look at it from behind the wheel well. I mean if its completely stuck might as well have a second look from the back... |
Low Beam. I'm trying to get away from having to remove parts to replace the bulb but i may need to in order to get it out. My hand somehow fit into that small gap next to the battery so i've been trying to crank that thing out until my hand hurts. Then i call it quits.
| BULB/Lamp Replacement Guide =) | whitecivicsi | Lighting, H.I.D.'s, & Neon | 236 | 01-30-2010 10:39 AM |
| head lamp adjustment | polaris420 | Lighting, H.I.D.'s, & Neon | 3 | 10-27-2008 10:46 PM |
| song stuck in head. | BLU BY U | Water Cooler | 39 | 12-14-2006 04:00 PM |
| song stuck in head re-visited.... | skiz | Water Cooler | 4 | 12-14-2006 03:53 PM |
| song stuck in my head | imtim25 | Water Cooler | 6 | 10-12-2006 03:02 AM |
