100 watt low beam (9006) bulb too much? - 8th Generation Honda Civic Forum
Old 02-16-2009, 03:15 AM   #1 (permalink)
TurboBlue's Avatar
So i was wondering if anyone has heard of blowning a fuse from running bulbs with higher wattages? I do intend to use an uprated wire harness but doesn't the fuse blow first before the wire harness gets fried? Are the fuses pretty easy to buy and replace? Im quite a noob with regards to electrical stuff.
I know a lot of people run the 80w bulbs (on low beams 9006) with no issues on stock harnesses but i was thinking of 100w but wasn't sure if that would be a little too much for the fuse.
TurboBlue is offline
Old 02-16-2009, 03:18 AM   #2 (permalink)
av911's Avatar
Why would you want to?
Old 02-16-2009, 03:18 AM   #3 (permalink)
jethroooo's Avatar
why not just get HIDs?
35w.
jethroooo is offline   Reply With Quote
Old 02-16-2009, 03:25 AM   #4 (permalink)
TurboBlue's Avatar
I would do HIDs but only if i get them retro-fitted. And getting them done by customlightz really isn't cheap!
So for now i was just thinking of tiding myself through with brighter bulbs. I got stock wattage aftermarket Piaas and they are really disappointing. So the reason for going 100w would really be for better light output.
Any ideas on the fuse issue? And i suppose u can pick fuses up from autozone/pepboys should you blow one?
TurboBlue is offline   Reply With Quote
Old 02-16-2009, 03:28 AM   #5 (permalink)
jethroooo's Avatar
actually replacing your stock bulbs with another set of "brighter" halogens will not do the job.
1) you'll lose more light output.
2) stock bulbs are brighter than those.
3) wattage over 60w will kill somewhat kill your wiring.
and there are many more man.
Old 02-16-2009, 03:32 AM   #6 (permalink)
TurboBlue's Avatar
Yeah i know there are aftermarket bulbs that have worse light output than stock because of the blue coatings but i've seen some 80w ones which are really bright.
Old 02-16-2009, 03:37 AM   #7 (permalink)
jethroooo's Avatar
I've been there before.
I actually bought nokya 100w bulbs and they really looked BRIGHT.
but then I soon noticed the output of what they produce while driving didnt
look too good. I noticed I lost output which was true after reading and researching
about them.
and why dont you get HIDs?
and to answer your fuse question. if a fuse blows, then you have an extra set of fuses under your hood in the fuse box.
Old 02-16-2009, 03:56 AM   #8 (permalink)
TurboBlue's Avatar
Hmm..appreciate the input man. Yeah i will do HIDs but only if i get retros. And getting them done by customlightz is really expensive so for now, i might just go with 80w nokyas or something..
Old 02-16-2009, 04:04 AM   #9 (permalink)
VanSi07's Avatar
Get HIR bulbs. There's a sticky on them.
VanSi07 is offline   Reply With Quote
Old 02-16-2009, 04:22 AM   #10 (permalink)
TurboBlue's Avatar
Yeah i saw those but im a sucker for looks too..haa..i do want the whiteness of aftermarket lights.
Old 02-16-2009, 09:06 AM   #11 (permalink)
Br3aker4lyfe's Avatar
Philjay
Buy some aftermarket projector headlights, alot of them look really ugly with the LED's and halo's but if you look around I've seen some clean looking ones with just Halo's, and then you can get H1 type HID;s cuz thats what most of them run on. 4500k = whiteness
Br3aker4lyfe is offline   Reply With Quote
Old 02-16-2009, 12:07 PM   #12 (permalink)
jose
hids
zetarin71 is offline   Reply With Quote
Old 02-17-2009, 03:52 PM   #13 (permalink)
FALer's Avatar
Haywood Jablomi
Nobody mentioning the increased heat from doing this? Or that your entire headlamp housing and lens are made of plastic?
All About Headlight Bulbs - Team Integra
Old 02-17-2009, 04:23 PM   #14 (permalink)
TurboBlue's Avatar
Thanks for the link. Yeah i guess im not gonna go with the 100W ones. Probably not worth it in the long run.
Old 02-17-2009, 04:39 PM   #15 (permalink)
FALer's Avatar
Haywood Jablomi
Stick w/ HIR or anything that doesn't draw more than 65W.
low beam bulb change cto424 Lighting, H.I.D.'s, & Neon 14 02-23-2009 11:46 AM
Low beam bulb explodded Honda247 Lighting, H.I.D.'s, & Neon 16 11-10-2008 11:34 PM
Remove Low Beam Bulb Help oconn11 Civic Coupe And Sedan 16 11-07-2008 06:12 PM
