Jeff
HELP!!!! HID's not working in fogs!!!
installed 6000k h11 HID plug and play set up in in to my fogs and they won't light up. I have a 6000k set up in my lowbeams thats works flawlessly for over a year now that i installed myself too. does anyone know why they won't light?
Jeff..REAL FRIENDS> car clubs!
no noise fromt he ballast either... maybe its a bad kit??? swith the ballast of the head lights to the fogs and see if its the ballast???
maybe something came loose in the fog wiring.. did you plug the harness directly into the ballast??? thats what i did with all the installs i did for our civics....
there is no need for the adapter the fog wiring should plug straight into the ballast.... if that doesnt work try flipping the connector around?? im sure there is a tiny nub where the connector goes and on the other side has a bigger nub???? try to connect it with the clips going over the bigger nub... sometimes these ballast we get are produced backwards... but first try to eliminate the extra harnes.. and plug wiring straight to ballast |
#15 (permalink) |
yea well try that. maybe even try to start the car up and turn then on.. maybe the fogs wiring is not sending the full 12v to ignite the ballasts.....
#17 (permalink) |
Nah it just might be a problem when the car is not on... Im not sure you can try it... But im still using the fuse the fogs came with...
wow i ont know man.. have you tried it with the car on and stuff or not yet? |
#19 (permalink) |
Jeff
yeah my roomate started the car and let it run and still nada. i disconnected the main power cord to the 9006 ballast and connected it to the new h11's and both set ups worked with that test, buls ballast and all... sorry i don't think i mentioned that before
| Ebay HID's not working. What could it be? | BolivianFuego | Lighting, H.I.D.'s, & Neon | 37 | 11-30-2008 02:32 AM |
| Fogs aren't working and one cracked... | R18Civic | Inside and Out | 2 | 02-24-2008 05:41 PM |
| OEM Fogs not working | Motorwerk | Mechanical Problems & Technical Chat | 8 | 09-30-2007 03:24 PM |
| Fogs stopped working | kevzSi | Lighting, H.I.D.'s, & Neon | 18 | 03-20-2007 03:42 AM |
| HID's in fogs and headlights pics | g00s3y | Lighting, H.I.D.'s, & Neon | 5 | 12-06-2006 01:10 AM |
