Hey Guys, i took your advice and installed my fogs myself. I completed it all and it came down to the moment of truth today...drum roll! NOTHING. My fogs arent working! i tried to check everything but cant figure it out. U can see i the pics that one connecter isnt attacted to anything and i'm not sure if its supposed to be. Also the fog lights on symbol is showing up on my gauges if that helps. Can anyone figure it out from these interior pics. Thanks!!!
Every connector should be hooked up from the light harnest. Sounds like you got one of the single wires that plug into main harnest that shows on the instrument panel. Does the switch button illuminate or glow when lights are on? That is what the other wire that plugs in is for. Check your ground wires? From those pics I cant tell which connector isnt hooked up. Refer to and check steps 19-23,35,and 36-46.http://collegehillshonda.com/instruc...oglightkit.pdf
Can not tell what you hooked up and didn't hook up. Check that the fuse is in slot #6. And check the wires harness on the fogs to make sure that every thing is tight, The connector behind the washer fluid gave me a hard time(didn't want to seat properly).
#9 (permalink) | |
The one Plug(BLUE) that is not connected in the pics you are showing, looks to be for other Acc. You said the switch is lit and the light on the dash is on so it look as if it is one up front. Did you connect the plugs when you put the bumper back on? |
#16 (permalink) |
Step #41 ...plug 6 pin connector into fuse box see pic.
page 9 and 10 http://collegehillshonda.com/instruc...oglightkit.pdf
#18 (permalink) |
Hey cornflake,
turn the head lights on then turn on the switch for the fog lights. do you hear the relay click? Does your set up have a relay? get a long insulated wire. connected one end to the + side of the battery. touch the other end to the brown wire connector with the single blue wire under the the dash. if everything is connected correctedly the lights should come on. if that works then you may have to jumper past the relay. |
#20 (permalink) | |
Hey could u explain that more. I have the relay plugged into the top the the relay harness. Where is it supposed to be plugged? |
| Cut-out fog light opening for CAI? | crazyj | Bolt-Ons And All-Motor | 11 | 09-02-2006 10:27 PM |
| FOG LIGHT HELP | wargate | Mechanical Problems & Technical Chat | 0 | 08-30-2006 12:23 AM |
| Is there oem yellow fog light lenses? | augydog | Lighting, H.I.D.'s, & Neon | 6 | 08-06-2006 07:32 PM |
| fog light install?? | taejinah | Lighting, H.I.D.'s, & Neon | 1 | 05-20-2006 07:57 PM |
