no more hid's
hi
i recently got rid of my hid's because they sometimes wouldn't turn on which is really annoying. i actually have better visibility and distance with out them. heres where i bought them stay away from this kit, the ebay seller is supervtec and the slim ballasts are called Xentec they were cheap so i guess you get what you pay for i had 5000k btw
#6 (permalink) | |
![]() going though the wheel well to put them in and take them outi'm happy with the halogens, it's not like the civic has projectors where xenon has the most benefit |
Kiet Quach
IM ALSO A VICTIM OF SUPERVTEC =[ !!! but my situation is different..the bulb colors arent matching because if you look directly at the bulb one is blue and the other is white. the output on the streets is still the same though. The ballast are in good working order just boo boo bulbs
#8 (permalink) | |
tell them one of the bulbs are wrong |
#10 (permalink) |
Were you using a HID relay kit? I bought the same brand from a different ebayer and have not had a single issue. I have had the kit for almost 3 months now. I did put in a HID relay harness when I installed the HID kit. I wonder if the lack of the relay kit may have been your problem?
#11 (permalink) |
the slim ballast are more likely to experience problem starting up because instead of using the traditional coils to step up the voltage, it uses change pump circuit as well. The charge pump circuity is very very easy to have collapsing waveform, causing the output to be at an insufficient voltage level to ignite the HID
All ballast (even from the same factory) are different. Some are simply better than the other ones. It's just by chance if you get a good or bad ballast. I never trust ebay sellers. but best of luck in confronting with him. I have one of those slim ballast as well. I got it from ClubLexus. If mine burns out, I'm switching back to stock bulbs. |
#12 (permalink) |
![]() Join Date: Mar 2006
asdfghjkl
I have the same Xentec slim hid kit that I have been using since July and have not had any problems. I had the 5000k bulbs that it came with but was not happy with the color(it was too blue than supposely white) or output so I ordered some different brand set of 4300k. Never had any ballast problems from it, always turn on without hesitation - even in -10s degrees too!
#13 (permalink) |
I have the same kit as well and from the same buyer since march and have not had a problem with them so far *knock on wood. I have also bought at least 5 more kits for my friends and they haven't had any problem as well..maybe u jus got a defected one
#16 (permalink) |
Honda has NOT been thinking lately, since gas got expensive and everyone wanted one !
My 97 accord, 2.2L was one of the best cars I have owned. Easy to do DIY and maintenance, build very well, no tranny issues at 120K and ran QUIET without any rattles (list goes on and on). 08 SI , built relatively POOR, rattles and issues.... |
#17 (permalink) | |
Jason
#18 (permalink) | |
i didn't want wires all over the engine bay since its a lease, also it was another 30$
| HID's | ap07civic | Lighting, H.I.D.'s, & Neon | 3 | 10-26-2007 07:40 PM |
| What best place to buy HID's? | 4drSidan | Lighting, H.I.D.'s, & Neon | 34 | 10-19-2007 11:55 PM |
| HID's | robinsonda1 | Lighting, H.I.D.'s, & Neon | 1 | 06-10-2007 02:34 PM |
| HID's | civicus07 | Lighting, H.I.D.'s, & Neon | 3 | 11-18-2006 04:06 AM |
