Im planning on buying this kit for my car which is an 07 Civic Si Sedan and was wondering if everything that is needed to make it plug and play is included in the kit or would I need to purchase something else like a harness?
if your buying from ddmtuning. The kit does not come with a Relay Harness. Although for a 35w kit you technically do not need the Harness, if you want added safety you can buy the harness.
So if you just buy the kit you should be straight.
Yeah thats what I was planning on getting. So i should be straight without the relay harness? Anybody that has had these installed did you have any problems in the long run?
if you use a 35W kit you shouldn't have a problem. If you were to ask me personally I'd run the relay harness just to make sure. I had issues with the 55W harness causing flickering and the stock connectors getting really warm. But nothing major. I just ordered a 35W kit and I plan on running a custom made relay harness I built out of $30 of wiring and plugs.
if i were you i'd use a relay harness just incase a year or 2 down the line and the ballast decides to die and might fry your stock relay. who knows right? 20dollars vs 200
Related Threads
12M posts
157.4K members
Since 2005
