Please help anybody,
yes, I'm a nuub and a boob since I can't figure out how these connections are made. Yea, I'm finally getting around to doing this, and everything looks pretty simple. But, what connects to the stock headlight connector? I have a female pin type on the stock side, but the Zenon Depot set up doesn't give any connectors even close to make a connection.
Did I place the right order? I have an 8th Gen Civic SI, and ordered the 9006/HB4 Part number: XT-4K-9006. and with no instructions.
It looks like the connector White and Black wire have no home to go to.
From the ballest the light plugs in, then the 2 way to mates to the relay WH. then from the relay I'm left with a 2 way that you would think would mate to the stock WH but it doesn't.
can anybody offer any help?
thanks
ps: do I need to tie down the grounds since the the stock WH is already grounded? Space is so fricken tight in there. CAn't I just tape them together> ( relay ground to fuse ground)??
hmmm, any way, any help would be great.
Jw
thanks
Jw
