Lights flickering on the passenger side - 8th Generation Honda Civic Forum
Old 12-08-2008, 09:42 PM   #1 (permalink)
octoberfestfan2008's Avatar
Hi folks,
Coming from Acura TL with HID, I figured I would put the HID Plug In and Play into my 2009 Civic Si Sedan. The vehicle is stock with the upgrade of HID. It was done about 10 days ago and today I noticed when I start up the car, the lights flicker a bit, and while I was driving, the passenger side flickered pretty intense. The light never went out, but it has this rapid flicker constant for a good 10 minutes before it became steady. The driver side was fine so my question is
A) Is it doing that because it's 28 degrees out? And needs to power up? (my TL which came with the factory HID never flickered.)
B) Is the right side balister(spelling?) a defect?
I called my carrier, he said the brand is from Europe and is a good private brand called (something DIGITAL...I forgot the name.) It is not one of those cheap product from ebay. He is a very reliable carrier who does alarm, turbo, s/c etc., He said it might need some additional harness since the right side isn't getting enough voltage...
is that true or BS? I am thinking if this is going to give me trouble, I might as well go back to stock Halogen. I still have the stock bulbs with me and I am afraid the flicker will make the bulb go out?
and by the way, after 10 minutes the light never flickered again.... so I am baffled.
Please help, I don't know too much about HID lights.
octoberfestfan2008 is offline
Old 12-08-2008, 09:44 PM   #2 (permalink)
btw it's a 6000k bulb, not the typical crazy 8000 or above HID. I went as factory look as I can.
thanks for your input in advance.
octoberfestfan2008 is offline   Reply With Quote
Old 12-08-2008, 10:09 PM   #3 (permalink)
db8typer's Avatar
Do you have a HID relay?
db8typer is online now   Reply With Quote
Old 12-08-2008, 10:19 PM   #4 (permalink)
Brian
My guess is that regardless of what the guy told you, the brand is just another cheap brand. I had a similar problem with my kit that I ordered through Fashtek, which sells German products supposedly. I tried switching the bulbs, and the same thing happened regardless of the bulb. So, I finally took the ballast out and it was full of water. These ballasts were supposed to be waterproof. I would start out switching the bulbs and see if the problem persists. If the other bulb flickers, then it is the ballast. Good luck. I'm getting to be a pro at taking my front bumper off because of these damn headlights.
VictoryIsMine is offline   Reply With Quote
Old 12-08-2008, 11:05 PM   #5 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Flickering can be caused by lower-end conversion kits that are universal in design. Now, not to say your kit is lower end, but it may be.
I had this problem too in my conversion kit when I had my 07 Civic Si, and it was the ballast that was to blame. Warranty replaced it and it didn't flicker as much.
I believe there should be a relay installed to eliminate fully the flickering problem. Remember you're going from 55w to 35w.
Darryl
Old 12-08-2008, 11:33 PM   #6 (permalink)
Yes, I believe it has something to do with the heavy rain on saturday night while I driving (over an hour and parked for about 6 hours.) The HID kit is suppose to be WATERPROOF, yet flickering began only on the passenger side day after the rain. I am heading to the shop and get my stock bulbs installed back. I don't want trouble and problems so I am just going back to original halogen lights and suck up the less visibility.
I am not about to have the bumper taken off, change the bulbs, more flicker, take bumper off, change ballast, it will drive me crazy. HID lights isn't worth that much trouble.
Old 12-09-2008, 03:21 AM   #7 (permalink)
striker_1818's Avatar
Christian
that's why OEM > ebay kits.
All great websites that sell you "OMGZ QUALITY HIDZ" are just relabeled ebay ballasts
striker_1818 is offline   Reply With Quote
Old 12-09-2008, 12:29 PM   #8 (permalink)
^ Negative. READING IS YOUR FRIEND. I bought it from a trusted authorized dealer under warranty, not from ebay.
Old 12-10-2008, 01:25 AM   #9 (permalink)
Christian
Sorry to tell you this but your "trust dealer" just bought a bunch of ebay ballasts as wholesale and rebaleled as their own.
Knowledge is your friend
Old 12-10-2008, 03:26 AM   #10 (permalink)
feichai's Avatar
i just had the same problem a couple days ago, my ballast got water in it and started flickering pretty bad until it went out.
feichai is offline   Reply With Quote
Old 12-10-2008, 04:43 AM   #11 (permalink)
Christian
its most likely the connection that's getting corroded with the water coming in from bad weather.
Old 12-10-2008, 05:03 AM   #12 (permalink)
feichai's Avatar
my problem was that i had gotten in an accident a while back, and took the ballast apart, so now it doesn't seal correctly, and so water got in and got effed up
Old 12-10-2008, 05:08 AM   #13 (permalink)
Christian
theyre cheap nowdays so ehh it's like tossing a halogen bulb nowdays lol
Old 12-10-2008, 11:27 AM   #14 (permalink)
true. I am now back to stock.
Old 12-10-2008, 03:26 PM   #15 (permalink)
Red_Devil's Avatar
Ethan
ewww stock *shudders*
Red_Devil is offline   Reply With Quote
Old 12-10-2008, 04:43 PM   #16 (permalink)
It's not that bad having stock. I am tired of dealing with HID flickering issues. I have seen plenty of eye headlight HID wannabe car out there. Our Si isn't that easy to change the ballast or the HID bulb itself. You have to take the bumper off or go around it, it's such a pain in the ass. NO THX.
Old 12-10-2008, 05:27 PM   #17 (permalink)
HTX
HTX's Avatar
Pnp kits make ur car look tacky and cheap. Retro or gtfh...
i bought a pnp kit and never installed it after seein so many ****boxes with them running around town. The new hottest mod among ricers and jackoffs in turbo diesel pickups... the only pnp kit i would use is for yellow fogs and thats still a slim chance.
HTX is offline   Reply With Quote
Old 12-10-2008, 05:40 PM   #18 (permalink)
Totally agree. There are many folks on this forum that use PnP HID kit and works fine. I give them props but I just don't want the headache. Coming from 2004 Acura TL, I missed the HID so I figured I would go to my trusted dealer to get a kit. The kit I have is very bright, and great quality but the flickering got me frustrated. 4 yrs I had on oem HID kit in TL never once flickered.
I can live with halogen bulbs, the fog lights that came with the car makes it visible enough.
Old 12-10-2008, 07:00 PM   #19 (permalink)
aNdRe
well all i did is cut the plug and play and rewiring the whole thing and its actually better... no more water goes in the socket.. i had them for 3 yrs with no problem... except one of my ballast died on me.... and that was it... the rest is fine...i did a research and they said that ballast dont really last long....
mistergizmo007 is offline   Reply With Quote
Passenger Side Rattle matok Mechanical Problems & Technical Chat 11 03-27-2011 03:50 AM
Passenger Side Air Bag Question pvr02 Dealership Experience 2 04-25-2008 05:11 PM
Passenger Side Mirror....gone... sikaren07 Civic SI 43 12-24-2007 07:47 PM
Am I the only one? No heat on passenger side Kroze Mechanical Problems & Technical Chat 0 12-22-2007 12:32 PM
Car tilting or leaning towards driver side more then passenger side.. imported_06civic Mechanical Problems & Technical Chat 8 04-05-2006 11:51 PM
