I have a question about factory fog lights. AFAIK all the OEM kits come with a stalk and are meant to be installed that way. Problem is, if the fogs were meant to be installed using the stalk, why did Honda decide to add additional switch plates next the the VSA button? Is it because Honda knew people wanted to do modding, or if they have another type of OEM kit that uses switches instead of the stalk?
Also, I'm about to order a set of fogs. Before I do so however I'd like to know the differences between OEM and aftermarket lights. The ones I currently know of are:
1. OEM stalk vs aftermarket switch
2. Bulb rings (OEMS have black shielding around the bulbs)
Are there any other notable differences?
