#141 (permalink) |
johnny
If anybody is wondering if there is any different between the coups and sedan bulbs. here is the sedans.
http://www.sylvania.com/ConsumerProd...RG-Results.htm |
#145 (permalink) | |
Rick
![]() u my friend are GREATLY mistaken Silverstars are a joke a marketing gimmeck they actually put out LESS lumens any bulb that is colored looses certain colors and therefore a certain amount of lumen output ALL silverstars are NOT as bright as the original bulb, no if ands or buts if u dont believe me, put on in each socket and compare at headlight level, youll find that the standard halogen is far brighter, just yellower than the silverstar! and yellow is necessary to cut thru fog ;-) why do u think our headlights dont come stock with silverstars if they are superior? if you need MORE light, there are only three solutions XtraVision (a few more lumens than stock) HIR (plenty more lumens than stock, a halogen with a IR coating that makes it burn brighter, but at the same wattage) HID (ALOT more than stock, brighter, but as illegal as any, and could potentially cause oncomming traffic eye damage depending on housing and aim, unless projectors are retrofitted into the housing instead) Those are your ONLY options, until me and an old member here figure out how to make our LED headlights work, which will produce the same lumens (alittle more actually) as an HID system ;-)
#146 (permalink) |
Brendan
Planning on getting two kits. one for the driving lights and one for the fog lights. will the 9005 (hb3) work for the driving lights? what does the (hb3) mean?
#147 (permalink) | |
Rick
9005 is high beam/driving lights, issue is that u cannot use HIDs with the DRL (daytime running lights) they will blow the ballasts |
#150 (permalink) |
Brendan
ok sweet thanks for clearing it up. so on this site VVME.COM LLC Your Best HID KIT Supplier it says 9006 (HB4) will that work?
#151 (permalink) |
Rick
any HID kit that cost 41 bux u should be VERY weary of
i only trust Digital (retro resources) and K-light (by kassabain on ebay) those are cheaper kits but good for the money, and even they are about 130 shipped (digital brand is actually a digital ballast too) 9006 is your low beam bulb if you do your high beam bulb (9005) it will blow the ballast on ANY hid system due to DRL also only 4300 K is recommended, anything above that you are loosing lumens AND cant do long drives due to EYE FATIQUE |
#152 (permalink) |
Brendan
Anybody Care For Some Cheap HIDs?
a lot of people on here seemed to order these and worked out good. i just want something to hold me off till i can afford a retro. |
#153 (permalink) | |
#159 (permalink) | |
I searched HIR 9006 and I got nothing on ebay Last edited by nej_civic; 11-20-2008 at 10:08 PM. |
#160 (permalink) |
Rick
its a 9012 ;-) 9011 for 9005 / 9012 for 9006 |
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/10184-bulb-lamp-replacement-guide.html
| BULB/Lamp Replacement Guide =) - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 12-09-2007 11:41 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 12-06-2007 05:22 AM | |
| Wiper Blades Replacement | monkey323i | CorSport | 25 | 01-21-2012 12:08 PM |
| 2006 Civic Rear Speaker Install Guide | webby | Audio | 36 | 10-18-2011 09:12 PM |
| K&N replacement filter | H3DTRNR | Intake & Spacer Discussion | 8 | 12-01-2008 02:51 AM |
| GUIDE: 7thGen Nitrouse FAQ! | Paradoxblue | Nitrous Oxide | 0 | 04-24-2006 11:34 AM |
| gas cap replacement? | aznboi04k | Inside and Out | 3 | 04-06-2006 12:55 PM |
