#122 (permalink) |
Rick
if you do with HIDs youll have to pull the fuse for the day time running lights
otherwise you will blow the hids hids CANNOT be used for Day time running lights, they will be damaged high beam hids are never recommended, and unnecessary if you have low beam hids |
#123 (permalink) |
Jeremy
this might seem like a newbie question, but license plate light holder that holds the light bulb in, how do i pull the light bulb out of it? do i just keep pulling on the bulb or is there a way
#125 (permalink) |
Hi. Has anyone here used those angel eye projection lamp? like those in BMWs and Lexus? Where can I get them?
Like this YouTube - Halo Honda Civic Projector Lights 2008 |
#128 (permalink) | |
+1
your my hero for the day man! Quote:
#129 (permalink) | |
Rick
silverstar bulbs do come in h11, but considering they put out LESS lumens than a standard Sylvania Xtra vision, why bother? just cause its whiter? so what? your best bet is the sylvania xtra vision, otherwise check out retro-solutions.com ive talked to the owned before, those kits are really good (not according to him, thats out of other peoples experience, he showed me rate of returns and stuff like that which was super low) |
#132 (permalink) |
Rick
it uses approx 25%
nothing usable for HIDs, you still can get yourself any HIR or halogen bulb (HIR is the higher output that youll need to cut a tab to fit, only one seller on ebay, pricy but worth it!) |
#133 (permalink) |
the reason i'm asking is that I see many people on here using those nokyas hyper yellow 9005 bulbs but they come in 80w. If they only use 25% of the wattage, then the harness shouldn't melt right? unless you use the high beams a lot.
#134 (permalink) |
Rick
the harness can still melt, halogen heats up fast, it wont melt from being a day time running light, but if u run them for a few minutes they will heat up way too quicky
your best bet is getting standard 65 Watt yellow bulbs, they are hard to find sometimes but u can i still dont know why you would want yellow, it doesnt do great for illuminating the road in my opinion, things look weird, kinda throws of your eye sight lol my friend dropped them on his si, looked good from the front, not so much from the drivers seat lol not to mention your actually loosing light output by getting a yellow bulb if nething your best bet is an HIR, more light, slightly whiter than standard halogen, and 65watts! nothing beats that lol |
#135 (permalink) |
hey guys im a newbie
are these lights good for DRL is the voltage okay?? Nokya Arctic White 9005 Halogen Bulbs newbie lol thanks |
#136 (permalink) |
Rick
negative, they arent
first off the draw 100 watts, you high beams draw 65 watts (more wattage = more heat and more chances at things melting ;-) ) if you want the same wattage, and more output that limits you to HIDs or HIRs HIDs in highbeams arent always recommended as its IMPOSSIBLE to flick them without damaging the bulbs or ballasts whereas HIRs are still halogen, but with a film on the inside the keeps the heat on the filament, so it burns brighter they are about as expensive as silverstars (silverstars are LESS lumens than stock bulb tho!!!! just whiter) that is the link to the ONLY seller ive been able to find with the toshiba ones GE developed it, and sold it to toshiba, its in weird cars like Vipers and stuff but theres a tab you can pop off and make it a 9005 bulb just like that (requires some cutting of base, but he marks off where for you!!!) high beam equivelant is 9011 cut tab its now a 9005 ;-) 65 watts and way more lumens!!! the low beam version is a 55 watt 9012 = 9006 with cut tab, and puts out the same lumens as your current high beams ;-) and actually lasts a decent amount of time! good investment for highbeams, tho low beams i still suggest a nice digital HID kit from retro-resources.com |
#138 (permalink) |
Rick
generally speaking, it SHOULD be ok
see its alot like using a sylvania florescent tube with Advanced ballast, it will def work and be fine there the problem is that alot of korean and chinese kits come poorly made, flaws and such, most Mcculloch ballasts arent too bad, but they still have a decent rate of failure and ur paying extra for not a whole lot more i know nothing about DDM lol, but research your companies before purchasing. I will be purchasing my Digital kit this winter once i get my car back from the shop (a whole mONTH to repair what that idiot did in a hit and run!) research research research man ;-) cause if you dont, youll be sorry research is why im buying digital, and going with 4300kelvins ;-) |
#139 (permalink) |
Matt
Nokya Arctic Hyper Yellow (Stage 1) 2500K
Output 12V 65W Actual = 80W Brightest What does that actually mean in the 65W Actual = 80W Brightest? Does that mean that they are firing at 65 watts, but produce light as bright as an 80 watt? Confusion has set in! |
#140 (permalink) |
Rick
welcome to marketing at its finest
its a 65W bulb they are CLAIMING is as BRIGHT as an 80 wattt.... is it possible? no not at all, its just more gimecks a TRUE light bulb will rate its lumen output, but not even sylvania does that with their silverstars... oh thats right, cause they put out LESS lumens than a stock halogen... got it! dont fall to gimicks, a yellow halogen is a yellow halogen, they will all be about the same lumen output |
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/10184-bulb-lamp-replacement-guide.html
| BULB/Lamp Replacement Guide =) - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 12-09-2007 11:41 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 12-06-2007 05:22 AM | |
| Wiper Blades Replacement | monkey323i | CorSport | 25 | 01-21-2012 12:08 PM |
| 2006 Civic Rear Speaker Install Guide | webby | Audio | 36 | 10-18-2011 09:12 PM |
| K&N replacement filter | H3DTRNR | Intake & Spacer Discussion | 8 | 12-01-2008 02:51 AM |
| GUIDE: 7thGen Nitrouse FAQ! | Paradoxblue | Nitrous Oxide | 0 | 04-24-2006 11:34 AM |
| gas cap replacement? | aznboi04k | Inside and Out | 3 | 04-06-2006 12:55 PM |
