BULB/Lamp Replacement Guide =) - Page 11 - 8th Generation Honda Civic Forum
Old 02-07-2009, 09:04 AM   #201 (permalink)
tda1337's Avatar
Rick
.... yes it is....
if those are TRUELY 70 watts youll burn out the harness and possible the fog assembly itself will get to hot as well
tda1337 is offline   Reply With Quote
Old 02-07-2009, 01:08 PM   #202 (permalink)
07ASMSi's Avatar
David
ok thanks, anyone here running on the nokya h11 70w?
07ASMSi is offline   Reply With Quote
Old 02-11-2009, 12:45 AM   #203 (permalink)
whats the bulb size for the reverse light bulb??
FockerJoe is offline   Reply With Quote
Old 02-14-2009, 03:47 AM   #204 (permalink)
07ASMSi's Avatar
David
any 55w yellow fog light bulbs for sale anywhere? Thanks!
Old 02-16-2009, 04:37 AM   #205 (permalink)
JFunkLBC's Avatar
johnny
are nokya 80watts for the DRL ok? i got them off of ebay
JFunkLBC is offline   Reply With Quote
Old 02-16-2009, 06:42 PM   #206 (permalink)
Originally Posted by Slav View Post
i want to get them blue HIDs, but the truth is i donno what brand, and i know the size now, but are they legal, considering lexus is rocking them.
The reason Lexus is allowed to use them is because they've gone through rigorous safety testing. Putting Blue HIDs in your car, as well as most Bright White HIDs is going to be illegal. But, i guess it depends on local enforcement/knowledge. I know San Diego, CA police are pretty versed in aftermarket-modification law, haha.
But I'm still getting 6000k White HIDs =P (safer than blue anyhow).
LPhomiej is offline   Reply With Quote
Old 03-02-2009, 07:14 AM   #207 (permalink)
Soichiro Jr.'s Avatar
Thumbs up Bulb choice help
Hello-
I was hoping that someone with knowledge about led replacement bulbs could help me out please. First, I'm looking to change out my DRL/Highbeam 9005 bulbs. I've been looking at these-
eBay Motors: Acura NSX 02-05 18 SMDs LED 9005 High Beam Light Bulb (item 350169227716 end time Mar-22-09 21:28:27 PDT)
eBay Motors: V-LEDS HID WHITE 68 M-SMT DRL BULBS HB3 9005 VS (item 220364168385 end time Mar-20-09 02:37:05 PDT)
eBay Motors: L-1081 2PS 9005 BULB SMT SMD 68 LED HID WHITE FOGLIGHT (item 360134791995 end time Mar-04-09 20:01:02 PST)
Can someone please tell me the differences between the various types of leds used on the different 9005 bulbs listed above? Also, which of these bulbs would perform the best during highbeam duties???? Since the leds use way less power than halogen bulbs, when they are in DRL mode, will they look the same(brightness-wise, lol) as when they are in Highbeam mode????
Next, I'd also like to use leds for the fog's H11 bulbs. I've been looking at these-
eBay Motors: L-1085 2PCS H11 BULB SMT SMD 68 LED HID WHITE FOGLIGHT (item 110355965806 end time Mar-03-09 01:44:39 PST)
eBay Motors: Acura RL 2008 05 06 07 08 18 SMD LED H11 Fog Light Bulb (item 350169228565 end time Mar-22-09 21:33:28 PDT)
Of the 2 H11 bulbs listed above, which ones would be brightest???? Thanks to anyone who can help out.
Soichiro Jr. is offline   Reply With Quote
Old 03-02-2009, 09:16 AM   #208 (permalink)
tda1337's Avatar
Rick
Originally Posted by Soichiro Jr. View Post
Hello-
ok GOOD! no one else has responded yet. That means u havent gotten any info thats wrong yet
leds are currently (unless custom made) NOT bright enough to use as high beam bulbs. If you are replacing your high beam bulbs with leds, they will be come useless
the same goes for the fog lights. LEDS are again NOT the way to go, DESPITE what you may have read on other websites. I have found ALOT of misleading info about how bright leds can be, its untrue.
The brightest led on the market puts out 900 lumens at 11 Watts. Your fog lights are still well above that. your high beams are WAY above that
while the led is MUCH more efficient, JUST the led, no plugs nor circuitry goes for at least 20 bux an led
they also can burn up VERY easily, therefore due to heatsinking problems, have not been used in headlamp lighting at all
leds on ebay boast untrue lumen and MCD output. a super flux led is NOT capable of "100,000 MCD! at 140 degreees!" thats not possible and never will be
if you use the MCD calculator on superbrightleds.com, ull find that that particular led, only running .5watts somehow produces a couple hundred lumens... NOT POSSIBLE
if you are doing this for show, just know that it will be a good idea to do an HID projector retrofit in the low beams, therefore you may not need the high beams and fogs.
but i NEVER suggest using the current premade LED packages for headlights
i am currently doing research to the likes of an LED headlight, but its expensive and i have run into spread and cutoff issues (dont wanna blind people with headlights lol)
the only led headlight i know of is on that 80,000+ lexus v8 hybrid
but the lumen output is still not what it could be (only slightly better than halogen)
Old 03-04-2009, 06:22 AM   #209 (permalink)
Thumbs up Thank You...
Thanks for killing my led dream tda1337, ha. No, I really appreciate your response, very detailed and informative. Thanks for saving me some dough. ..... I wish you luck on your led headlight endevour! When you perfect it, let me know......
Old 03-04-2009, 04:44 PM   #210 (permalink)
Jo-Von-E
Geovone's Avatar
Jhovany M.
Just wanted to see how many people got the wire harness with 9006 bulbs? I mean, I've heard that they really don't need them but it'd be a safe bet to have the wire harness, correrct?
Geovone is offline   Reply With Quote
Old 03-23-2009, 10:53 PM   #211 (permalink)
Peter Kim
hey does anyone know where to get a good price on the stock high/drl bulb, mine burnt out and i want to get a replacement but i dont wana get ripped by honda.
d0ntg0m0ng is offline   Reply With Quote
Old 03-23-2009, 11:17 PM   #212 (permalink)
VanSi07's Avatar
You can get a 9005 bulb anywhere man, any auto store.
VanSi07 is offline   Reply With Quote
Old 03-24-2009, 12:16 AM   #213 (permalink)
CivicSi907's Avatar
Thomas
What type of bulbs are these?
dont pay attention on the written there.
CivicSi907 is offline   Reply With Quote
Old 03-24-2009, 09:23 AM   #214 (permalink)
tda1337's Avatar
Rick
go to walmart
buy the Sylvania XtraVision (clear bulb but truly better output)
9005
its the only halogen replacement bulb i would trust
dont buy Ge Nighthawks and DONT buy sylvania silverstars, THEY ARE NOT BRIGHTER, only "whiter"
Old 03-24-2009, 09:24 AM   #215 (permalink)
tda1337's Avatar
Rick
those are SMD leds, not worth replacing, they will last the life of the car
Old 03-29-2009, 02:09 PM   #216 (permalink)
crazigee's Avatar
What is the replacement bulb # for the 3rd brake light? (The one in the rear windshield)
Thanks,
CG
crazigee is offline   Reply With Quote
Old 04-07-2009, 02:15 AM   #217 (permalink)
JFunkLBC's Avatar
johnny
so one of my yellow fogs light burnt out i guess, not really sure because everything looks fine, 55w? and 80w for the drl fine or no?
Old 04-08-2009, 06:27 PM   #218 (permalink)
tda1337's Avatar
Rick
55 watt for low beam/fog light
65 watt for highbeam
DO NOT EXCEED THE WATTAGE RATING!
if u want more light, look up HIR and HID replacements
Old 04-08-2009, 06:27 PM   #219 (permalink)
tda1337's Avatar
Rick
Thanks,
CG
Genuine Honda Accessories at Discount Prices - Honda Product Information, Videos and News
enough said ;-)
i got a great price on mine
Old 04-09-2009, 02:15 AM   #220 (permalink)
JFunkLBC's Avatar
johnny
oh crap. i went over the watts then. lol does anybody know which fuse to take out the drl?
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/10184-bulb-lamp-replacement-guide.html
BULB/Lamp Replacement Guide =) - Page 5 - 8th Generation Honda Civic Forum This thread Refback 12-09-2007 11:41 PM
BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 12-06-2007 05:22 AM
Wiper Blades Replacement monkey323i CorSport 25 01-21-2012 12:08 PM
2006 Civic Rear Speaker Install Guide webby Audio 36 10-18-2011 09:12 PM
K&N replacement filter H3DTRNR Intake & Spacer Discussion 8 12-01-2008 02:51 AM
GUIDE: 7thGen Nitrouse FAQ! Paradoxblue Nitrous Oxide 0 04-24-2006 11:34 AM
gas cap replacement? aznboi04k Inside and Out 3 04-06-2006 12:55 PM
