#181 (permalink) |
Rick
im confused
ur getting rid of the red? if so there must be a small square or circle of reflective red still in it to be legal i would do leds get these for a CLOSE to oem look and function but clear closest to oem look//function decent build quality i have this version : will be installing in the summer time! |
#183 (permalink) |
Ok i think ive got most of this down as i have been searching a lot. I want to get yellow fogs to go along with my 6000k HID low beams. I have found many H11 bulbs to go in clear OEM fogs (not retro fitted). I am a little confused by the whole wattage thing. 35W is the proper amount for the fogs (H11)? I have only found 55W ones. Can i put 55W H11 bulbs in my fogs without them melting or do i need a wiring harness/ballast like my HID low beams? I found these online. I was just planning on getting the bulbs but will i need a harness for 55W? I may just go with 35W if i need to. Im just a little confused.
Luminics JDM Yellow (H11) Headlight Bulbs|Luminics Headlight Bulbs|Luminics Lighting Products because those say 55-130w?? |
#184 (permalink) |
Rick
a) where did u hear its "35" watts... its 55, same as low beam bulb, 55 watts
b) those are the most common used 55 watt yellow bulb, yes they are 55 watts, but they use gimicky marketing to claim it has the output of a 130 watt bulb.. which it CLEARLY does not to be DOT legal lol yellow will be only good for fog tho, so unless u live in the new england area or an area with dense rain/fog, i would suggest just sticking with a set of XtraVisions (DONT EVER DO SILVERSTARS< THEY ARE A GIMMICK AS WELL!!!) high beam bulb can be grabbed from inside the engine bay and rotated, comes right out |
#185 (permalink) |
Jo-Von-E
![]() Join Date: Jul 2008
Jhovany M.
Okay I have been looking through the internet looking at different bulbs and such...and came across a pair from passwordjdm.com. My question is...has anyone bought them and how do they look? My other question is would these bulbs fit, I mean it does say the correct fitment number...9006.
My other question is, meow I know this may sound n00b-ish but what does the wire harness that some bulbs offer do? In fact, what is it? Like do you really need it? Last edited by Geovone; 01-02-2009 at 03:41 AM. Reason: Adding to my question |
#186 (permalink) | |
Haha, i actually do live in the New England area and i travel through the Poconos a lot. Any way, it looks like i will purchase those for my fog lights. Thank you |
#188 (permalink) |
Rick
do your research and then it wont sound noobish
any harness takes power direct from the battery when power surges thru your stock harness, that way to not blow your stock harness that goes back to your light stalk 9006 = 9006 u answered your own question not sure what bulbs they offer BUT blue bulbs, or ghetto ebay bulbs = horrible output (that INCLUDES sylvania silverstars) yellow bulbs = less output but yellow (good in rain/fog) |
#192 (permalink) |
question...after putting in my new smoked led tail lights, I noticed one of brake lights is burnt out. It's not THE brake light as it was replaced by leds. INSTEAD, it is that very small and stubby looking light that plugs in just to the side of the main brake light. It goes into where the reflectors are along the side. What size bulb is THAT?
#193 (permalink) | |
Mike C.
Back Up Light Bulb Size: 921 So if you could get some help from someone at home to see if ur back up light is burnt out. |
#196 (permalink) |
Do you suggest a certain type of led? For example, some led bulbs have several leds on them or some have almost microscopic leds that look like yellow dots on a flat surface. I was planning on replacing them with leds but didn't know the exact type of bulb. thanks
#197 (permalink) |
Rick
the microscopic leds as u call them
this is a cluster led set that is always better than those stupid nichia leds found in cheapo flashlight its gonna be a really small bulb tho, just remember that and the more u pay (from the SAME vendor, either vleds or warden on ebay) the better the led of course |
#198 (permalink) | |
#199 (permalink) |
Rick
a nichia led is like your standard led
what you think of when u hear led, its simply a elongated half circle that is intense but only from one direction alot of places mislead using those and superflux leds saying they put out more lumens that even a car headlight this is by FAR, not true high power leds are only starting to be released that are close to the power of a headlight for instance the SSC p series contains a 10 watt led that puts out 900 lumens. a nichia led MIGHT put out 3 lumens luxeon is known for high power leds as well, but nothing in the SSC light output yet neways i dont have a link just go to v-leds.com its the same stuff youll find on ebay i havent replaced those cause i still havent put on my led taillights once i do ill buy a set verify the bulb name/size with sylvania's website for bulb replacement |
LinkBack to this Thread: http://www.8thcivic.com/forums/lighting-h-i-d-s-neon/10184-bulb-lamp-replacement-guide.html
| BULB/Lamp Replacement Guide =) - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 12-09-2007 11:41 PM | |
| BULB/Lamp Replacement Guide =) - Page 4 - 8th Generation Honda Civic Forum | This thread | Refback | 12-06-2007 05:22 AM | |
| Wiper Blades Replacement | monkey323i | CorSport | 25 | 01-21-2012 12:08 PM |
| 2006 Civic Rear Speaker Install Guide | webby | Audio | 36 | 10-18-2011 09:12 PM |
| K&N replacement filter | H3DTRNR | Intake & Spacer Discussion | 8 | 12-01-2008 02:51 AM |
| GUIDE: 7thGen Nitrouse FAQ! | Paradoxblue | Nitrous Oxide | 0 | 04-24-2006 11:34 AM |
| gas cap replacement? | aznboi04k | Inside and Out | 3 | 04-06-2006 12:55 PM |
