Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 05-12-2008, 05:42 PM   #1 (permalink)
BlackHFP's Avatar
DIY - Schroth Racing Harness install for Sedan (Coupe should be similar)
Originally Posted by BlackHFP View Post
Hey everyone - First off I want to say thanks to everyone that provided constructive input on this install. I would not have known to contact Schroth if you all had not spoken up.
I am sad to say that I have requested that this thread be locked and the DIY removed. After speaking with the manufacturer about some concerns raised by other members I have decided to change the install. Once I receive the parts from Schroth and get them installed I will be doing a new DIY.
BTW the install is correct; the stock seat just is not approved by Schroth. They said they are 99% sure that the stock seat can take the forces necessary, but I don't want anyone to do my DIY then have an accident and be in that 1%. I purchased a new strap and will be attempting to convert the harness into a Ralleye 3 (the mount will be on the rear outer pillar.)
Just to reiterate - This DIY was for informational purposes only. I take no responsibility for your install. Please use common sense; you are modifying a factory safety system. If you are unsure of your abilities to complete this install please do not attempt it. Once again installation using my instructions is at your sole risk.
Thank again for everyones input.
Mat
diy temporarily removed.... will be updated
BlackHFP is offline   Reply With Quote
Old 05-12-2008, 05:51 PM   #2 (permalink)
Si Speed 317's Avatar
Dan - GT3076R Fanboy
Is this the safe, correct way to use this? +1 for install tbw
Si Speed 317 is offline   Reply With Quote
Old 05-12-2008, 05:54 PM   #3 (permalink)
BlackHFP's Avatar
This is the proper installation for the harness. Since it uses the stock bolt locations and still uses the stock mounts there is no degredation to the safety of teh stock system. Also, even though this harness is DOT legal I would not recommend using it on the street simply because you can't even turn around to see if anyone is next to you.
Old 05-17-2008, 11:53 PM   #4 (permalink)
Omega87's Avatar
Matt
When you use those belts the stock one isn't fastened right? Wouldn't the 'fasten seat belt' alarm be going off all the time?
Omega87 is offline   Reply With Quote
Old 05-18-2008, 12:09 AM   #5 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
not in the rear
sh33t_0f_p4p3r is offline   Reply With Quote
Old 05-18-2008, 12:49 AM   #6 (permalink)
BlackHFP's Avatar
When you use it you can fasten the stock belt behind you. At least thats how I plan on doing it.
Old 05-18-2008, 01:47 PM   #7 (permalink)
i read somewhere that the best angle to have the harness is at 180 degrees as it leaves the seat. This means that you nêed a roll cage that has a tube going right behind the seats. It should still work gơod how you did it though.
tsuru_ser is offline   Reply With Quote
Old 02-27-2009, 02:16 PM   #8 (permalink)
07gen8Civic's Avatar
Brent
ressurected sorry, i needed to ask a question and didnt feel like it was good to create another thread for it.
Wont my "no seatbelt" alarm from the stock system go off, and start beeping?
07gen8Civic is offline   Reply With Quote
Old 02-27-2009, 02:36 PM   #9 (permalink)
MStayt's Avatar
Michael
You can just wrap it around the back of the seat and clip it in there.
MStayt is offline   Reply With Quote
Old 02-27-2009, 02:37 PM   #10 (permalink)
Brent
naw thats not it, its the fact that unless the belt in the front belt is clipped in, then the sensor will keep going off, can we turn that off?
Old 02-27-2009, 02:55 PM   #11 (permalink)
MStayt's Avatar
Michael
What I mean is run it behind the seat and clip it in where it normally would be. It'll be out of your way but still clipped in so it won't beep.
You could also probably go to a junk yard and see if you could find just the clip part of the seatbelt.
I don't think you should run the harness for DD so you probably shouldn't disable the chime.
Old 02-27-2009, 03:06 PM   #12 (permalink)
BlackHFP's Avatar
Thats exactly what I do. It is annoying and all heck though when you forget and then the chime starts going off... and your already on your way lol.
Old 02-27-2009, 04:47 PM   #13 (permalink)
Brent
id prefer to disable it, i NEVER forget my seatbelt, and at this point, it would just be really annoying
Old 02-27-2009, 06:07 PM   #14 (permalink)
MStayt's Avatar
Michael
I think the mods would have something to say about disabling that feature. I think it was discussed at one time but got deleted.
Old 03-07-2009, 08:00 PM   #15 (permalink)
disboikiet's Avatar
Kiet Quach
yea maybe there could be a relay of some sort to cancel out the sensor
disboikiet is offline   Reply With Quote
Old 03-09-2009, 12:42 PM   #16 (permalink)
Frankie Figs's Avatar
You can call me Mr. Figs
Originally Posted by tsuru_ser View Post
i read somewhere that the best angle to have the harness is at 180 degrees as it leaves the seat. This means that you need a roll cage that has a tube going right behind the seats. It should still work gơod how you did it though.
You're right. The way these harnesses are installed will cause your spine to get compressed in a crash. When you get thrown forward the harness is going to try to straighten out between your shoulders and the mounting point. Since the mounts are on the floor its goin to put force down on your shoulders and end up pushing down on your spine.
"The height of the shoulder strap mounts is critical because if they are too low they can actually compress the driver's spine in a collision."
Source: Page 3 of this article Racing Seat and Harness Installation - Car Racing Safety Tech - Anchor In
Frankie Figs is offline   Reply With Quote
Old 03-09-2009, 12:48 PM   #17 (permalink)
darkrom's Avatar
Matt
I just think it sucks that we aren't able to discuss disabling the chime the RIGHT way. People are cutting wires and losing airbags just to avoid the chime because we can't talk about how to do it better. I have the same harness in my coupe and need to find a solution.
darkrom is offline   Reply With Quote
Old 03-09-2009, 12:51 PM   #18 (permalink)
darkrom's Avatar
Matt
I don't get how you made just the lap belt visible for DD use. I really like how clean your install is. Mine is a mess which is why it is more or less just a jungle in my lack of a backseat.
Old 03-09-2009, 04:58 PM   #19 (permalink)
Ayodog's Avatar
rori
This install is completely done wrong by the looks of it. Theres a 45 degree angle being made which is by far much too big of an angle and will mess you up in an accident.
Ayodog is offline   Reply With Quote
Old 03-09-2009, 11:35 PM   #20 (permalink)
civicmarc's Avatar
Señor Marcos
a little much for a less than 200hp hp car?
civicmarc is offline   Reply With Quote
DIY: Megan Racing Midpipe install FG-JOE Do It Yourself Articles 23 06-26-2008 04:06 PM
Looking for DIY Sedan HFP kit Install? HELP PeterC. Do It Yourself Articles 4 03-04-2008 11:42 AM
VIS Racing Carbon Fiber Hoods available for Coupe AND sedan skittleslegend Civic Coupe And Sedan 28 08-09-2006 12:26 PM
DIY install of new head unit in sedan UK/AUS aussiebuddha I.C.E., Electrical, Security, & Navigation 4 04-04-2006 03:30 PM
