#1 (permalink)
DC5 Dead rest pedal. Mini diy.
I have received several requests for showing how the DC5 dead pedal was setup in my fg2 here are the pics. It is quite simple.
First, I mapped out where the pedal would lie on the stock dead pedal. I cut off on the bottom, top, and lower left side of the stock dead pedal. It should look something like this: It is important not to cut the upper mounting point off. You must only cut the top portion and then follow the the sideline to the top. The red stuff is where i cut. ![]() Next I filled in the back upper portion and the front upper part with duroglass, or you can use bondo and achieve the same results. I then sanded the front upper part so it would end in an angle towards the carpet. ![]() ![]() The next image shows the lower left side cut. There is no need to smooth it off since it is not going to be seen, nor is the bottom. ![]() Now that the frame was ready, I used very thin velcro, I used some HQ 3m stuff. Placed it on the sruface of the sock dead reest, and on the back of the DC5 part. Be sure to cut a hole for the center rotating screw for future removal. ![]() ![]() Then stick it on. You may have to adjust it slightly when it is in the car. This is what it should look like in the end. ![]() ![]() Warning. If you decide to just cut the top portion without angling it towards the carpet. It will look bad. I did that way first, then reconsidered. I hope this helps. Its kind of a simple rushed DIY. Good Luck. Any ?'s, msg me. |
#12 (permalink) | |
Tuna Fiddle™
nice write up!
For Sale Forum Rules READ THEM!
LinkBack to this Thread: http://www.8thcivic.com/forums/interior-style-mods/25365-dc5-dead-rest-pedal-mini-diy.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-22-2008 12:10 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 10:44 PM | |
| DC5 Dead rest pedal. Mini diy. - 8th Generation Honda Civic Forum | This thread | Refback | 12-19-2007 11:13 PM | |
| DIY: Strutking Dead Pedal Install - 8th Generation Honda Civic Forum | This thread | Refback | 12-12-2007 09:04 PM | |
| DC5 dead pedal | blackdragoon | Inside and Out | 4 | 12-13-2006 09:19 AM |
| Door sills and dead pedal = new pics! | letsgoflyers81 | Introduction & Pictures | 25 | 11-23-2006 02:43 PM |
| factory matching Si dead pedal? | TreeFrog | Inside and Out | 33 | 09-16-2006 06:33 PM |
| Mini DIY - Fixed my elusive door rattle | PokeyD16Z | Do It Yourself Articles | 6 | 09-13-2006 09:17 PM |
