Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 02-09-2007, 05:20 PM   #21 (permalink)
The Orignal CivicPC
ohiocivicracer's Avatar
Kevin
they are all being installed today!!! i should have pictures tonight when its dark!! wish me luck!
FIJI Crew # 3
The Original 8thCivicPC
ohiocivicracer is offline   Reply With Quote
Old 02-10-2007, 02:05 PM   #22 (permalink)
The Orignal CivicPC
Kevin
Well Here are the pictures :-)
i hope u enjoy as much as i am, lol
i got a little bored :-P so what...
FIJI Crew # 3
Old 02-11-2007, 03:25 AM   #23 (permalink)
sbigshot's Avatar
^^ looks good!
sbigshot is offline   Reply With Quote
Old 02-12-2007, 10:30 PM   #24 (permalink)
mishima8's Avatar
+1 looks good
mishima8 is offline   Reply With Quote
Old 04-09-2007, 04:49 AM   #25 (permalink)
yuning83's Avatar
Do you guys know why the kit (courtesy light) from Honda says it can not be installed on EX with fog lights installed? Is it a wiring problem? If so will I still be able to do a mod like this? I have a EX with fog lights installed...
yuning83 is offline   Reply With Quote
Old 04-09-2007, 01:02 PM   #26 (permalink)
smatts's Avatar
Matt
I believe it is because the switch that turns the OEM lights on and off fits in the same spot as where your current fog light switch would be. You can't fit 2 switches in that 1 space.
smatts is offline   Reply With Quote
Old 04-09-2007, 03:33 PM   #27 (permalink)
mishima8's Avatar
This mod is a non-switched mod. It's tied to the interior power, so it's auto on and off. You could add a switch to it and locate it somewhere though if you chose to.
Old 04-09-2007, 04:23 PM   #28 (permalink)
So...i'm very curisous and have a noobie question. Are u suing a seperate battery to keep the lights on under the cup holders and the little pocket?
No, right? If you are not, where did you attatch the wires under the cupholder? I just cant understand what to do with those wires underneath.
ckp_si is offline   Reply With Quote
Old 04-09-2007, 04:34 PM   #29 (permalink)
mishima8's Avatar
You are correct, they are all connected to the auxiliary plug in the center console. I taped them down to clean it up and I am debating redoing it another way because I am not happy with the way the reflect out from where they are now. Hope that helps.
Old 04-10-2007, 08:40 PM   #30 (permalink)
Megan
Thanks for the great photos mishima8. I was able to use them to find a power source for my XM hardwire.
RCURV is offline   Reply With Quote
Old 04-10-2007, 08:52 PM   #31 (permalink)
Camry Loverz
AbsoluteGG's Avatar
Steven
Does anyone have the courtesy light that Honda offers?
AbsoluteGG is offline   Reply With Quote
Old 04-10-2007, 08:53 PM   #32 (permalink)
Camry Loverz
AbsoluteGG's Avatar
Steven
BTW ohiocivicracer is your interior black?
Old 04-10-2007, 11:11 PM   #33 (permalink)
mishima8's Avatar
Glad I could help.
Old 04-11-2007, 05:09 PM   #34 (permalink)
thanks
do you mind posting a picture of your center console as of right now?
(opened) i would like to see how you made the electric available for it to light up
Old 04-11-2007, 10:04 PM   #35 (permalink)
mishima8's Avatar
thanks
It should be on the first page. Once you open up the console, it's the black and yellow wires. Does that help?
Old 04-12-2007, 08:51 PM   #36 (permalink)
So basically when u attach the LED wires to the yellow and the black wires under the console, it will use the power from the yellow and black wires to light up, correct?
Old 04-12-2007, 09:37 PM   #37 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
if you dont want the lights to make a concentrated spot, cover the led light with a grocery bag. try different kinds and it will spread out the lighting
datbacker59 is offline   Reply With Quote
Old 04-12-2007, 10:39 PM   #38 (permalink)
The Orignal CivicPC
Kevin
^^ i just sanded the end of the bulb... made it dull... it spred the light perfect
FIJI Crew # 3
Old 04-12-2007, 11:41 PM   #39 (permalink)
Josh
Anybody know of a good place to purchase these online?
TwofouroSi is offline   Reply With Quote
Old 04-13-2007, 01:35 PM   #40 (permalink)
mishima8's Avatar
That is correct!
