sagging shift boot quick fix
I came up with a simple quick fix for the sagging shift boot people are having with after market knobs. I went to home depot and bought a pack of rubber grommets (found them in the plumbing section). All you need to do is remove the knob and shift boot, place the rubber grommet on the lever (make sure you get the appropriate diameter to make a snug fit on it) reinstall the shift boot and screw the knob back on....
#7 (permalink) | |
all i did was place a rubber grommet O ring type thing on the lever so that when you reinstall the shifter boot and knob it keeps the boot pressed tight up against the knob so it doesn't sag and move around. and yes it is a skunk2 knob Last edited by ryanjacobson; 11-09-2006 at 03:07 PM. |
#8 (permalink) | |
nice knob btw |
#13 (permalink) | |
Not really sure where else you could find one. Maybe check out the internet the rubber grommet i used was originally intended for use as a seal in a faucet. But anything similar would work as long as if has the right diameter hole in it. |
| DIY Changing the Shift Boot (FG2) | FujiBlueSi | Interior Style Mods | 46 | 01-25-2010 01:04 AM |
| CSX Center Console! (+Auger Shift Boot) | andyman1080 | Inside and Out | 29 | 04-17-2009 09:09 PM |
| Momo Shift Knob and Boot | tmfrench | Civic Coupe And Sedan | 1 | 07-05-2007 04:38 AM |
| Does Augerresources shift boot fit Coupes? | joonoo | Inside and Out | 4 | 09-03-2006 07:21 PM |
| Voodoo Knob and Shift Boot Solution | Fixer | Inside and Out | 2 | 08-17-2006 11:38 PM |
